Bagged 04 layin frame
Ftruck - The Edge sticker hasn't faded yet, and it's been on there for about a year now. pretty good quality vinyl, it hasn't even cracked
Etrevino, that top link setup acts as a sort of triangulated link, the two joints at the truck act on each other to cancel the side to side movement.
There is a LITTLE movement side to side, but nothing more than a truck with a leaf spring would encounter. just can't take turns at 80 like you can in a mustang.
That's Haaaaaaaaaaaaaaaaard
Im mad jealous
Im saving up....just dont know how much and where to go over here in san diego, my friend's nissan hard body is having some issues since the guy who did the drop wasnt on point.
You mind if i email/PM you? got some Q's to ask ya
And anaheim drew too since your close by
keep it up man its badass
Im mad jealous
Originally Posted by Black3v
With a 3 link dont you need a panhard bar to control side to side movement of the rearend? Seems like without it it would be putting alot of stress on the joints of the 3 link bars.
to explain his setup its a very simple setup, first you have your lower bars just like any non triagulated 4-3-2link then there is the top bar which is the 3rd link which has 2 purposes 1) keep the pinon angle right and 2) keep the rearend centered side to side, which in a perfect world it would work great untill you go around a corner fast or have any body roll, if it were me id guset the crap out of the tabs that it mounts to and use a hiem on the axle end to allow some body roll
there is quite a bit left to do. when i started , i promised myself i wouldn't let it end up like the mini trucks that are always halfway done, and the bed is completely useless because theres a bridge almost as tall as the bed rails.
the tubs are sittin in the shop waitin to go in, and the wood floor with stainless steel inlay is soon to follow. the whole frame was coated with Chassis Saver (better than Por15) in satin black, so it looks like factory from the outside.
