adding 3/4 inch to the rear 4x2?
Old Jun 4, 2007 | 12:15 PM
one eyed willy's Avatar
well my rear is about .75 of an inch lower then my front,do they make a block this small,will i have to get new u bolts or is there enough threads for a 3/4 inch block?
Old Jun 4, 2007 | 12:19 PM
You'll have to have the block custom made and get some longer u bolts. (any machine or spring shop can handle this)
Old Jun 4, 2007 | 03:36 PM
Black3v's Avatar
My 4x2 came with a 1in block in the rear from factory so you might want to look into that as maybe a cheaper possibility. I think they started doing this on '07s.
Old Jun 4, 2007 | 03:52 PM
Black 2000's Avatar
You removed that block to make the rear sit lower at first?
Later...
Bruce
Old Jun 4, 2007 | 04:28 PM
Black3v's Avatar
Later...
Bruce
Yea I removed the block and added a 2in drop shackle to level out the truck at first. Then went another 2 inches front and back later on.
Old Jun 4, 2007 | 04:29 PM
Black 2000's Avatar
How did it look with just the block removed?
Later...
Bruce
Old Jun 4, 2007 | 04:41 PM
Black3v's Avatar
Later...
Bruce
Like an '04-'06 4x2 lol. If your truck is going to go down instead of up then just go for the 2" shackle since its a cheap mod and evens the truck out front to back.
Old Jun 4, 2007 | 06:19 PM
Black 2000's Avatar
She always gotta go down!
Later...
Bruce
Old Jun 4, 2007 | 09:00 PM
what did you do with your blocks?
Old Jun 4, 2007 | 09:55 PM
Black3v's Avatar
I can check to see if they are in the garage tomorrow-remind me if I forget
Old Jun 5, 2007 | 09:52 AM
that would be swesome if you still have them!!
Old Jun 5, 2007 | 05:35 PM
Black 2000's Avatar
If Black3V doesn't remind me in a month by that time I should have my truck and if I can get the back to look even with the front by removing that block it's all yours.
Actually you could probably go to the local parts shop and pick up a couple sets of blocks for 4x4 lift kits.
Later...
Bruce
