Transmission won't hold in Park!
My truck will not hold the truck in park. I am on the bed loading my ski's into the water, with my trucks parking brake on, and the truck in park. I'm on a slight hill and the transmission starts making a loud clicking and starts to roll back. For some reason it will not stay engaged in park if I'm on a hill. If I had gears it would hold it better but thats no excuse. Is this an indication of my transmission failing and can this be rebuilt/fixed?
Yeah that sounds like your parking pin is going out.
You can avoid the fix for awhile by using your ebrake to park like you should have always been using when parking on a hill to save that small pin any ways. Man you need to sell that truck in going to nickle you to death now. Tcase, starter, steering rack, Tranny!!
. Hopefully I am wrong about the pin but I know a guy that put it in park just slightly rolling and sheared it off and the tranny shop said the pins are always weak and to never rely on them on a hill anyways.
I always use my E-Brake to avoid situations like this. My truck holds itself pretty well on hills in Park with the E-Brake on. . if I don't use the E-Brake it goes into gear kind of rough and loud.
Originally Posted by Josiah
...with my trucks parking brake on
It is my own fault it sits the way it sits and I will bear the problems and repairs. However, next time around it will be in a superduty. I won't make the same mistake twice.
also my parking brake is way out of adjustment, yeasterday I had to park on a hill and pushed my ebrake down and let my foot off the brake and I still rolled right on to the parking paw. I put it in gear again to take it off the paw (with a loud clunk) and had to push my ebrake to the floor to get it to hold the truck.
