Thinking about uniball upper controll arms. Total Choas or Camburg. Are there others?
Old May 24, 2007 | 04:05 PM
kalebarellano's Avatar
Ok, one of my upper ball joints is going out. I was going to probably replace both. Which is like 160-180, for some that might not be that good. How much are a set of the uniball ones? Were can the best deal be found? How much longer would the uniball ones last?
Old May 24, 2007 | 04:09 PM
extremeethan's Avatar
my oppinion uniballs dont belong on street trucks. I was set to get them but then I heard about how they squeak and stuff and decided against them. Just my oppinion though. Also JD fab will make you custom billet uppers for like 800-900. I got new stock UCA for like 60 each when I did my lift and 50 for lower HD ball joints
Old May 24, 2007 | 04:19 PM
What are some good stock ones?
I found these:
http://www.trademotion.com/partlocat...04&catalogid=1
http://www.overnightautoparts.com/st...ntrol_arm&my=1
Should I also replace the lower ball joints? How hard is it to do that? And were did you get your HD ball joints?
I can count like 6 post by you on the board right now
jk eveyone has to learn stuff somewhere
Old May 24, 2007 | 04:22 PM
Your second link is for old body UCA's and I only replaced my lower because I had the AS and I beat on my truck. I figured why not when it is all torn down anyways. To change this stuff you would have to tear most of the kit back down.
Old May 25, 2007 | 12:56 AM
04procompLARIAT's Avatar
I have the Total Chaos uppers and they dont squeak one bit. I paid 700, installed them myself.
