Winch on a Ranch Hand Summit?
Does not look like there is enough room, but if you get the hidden hitch, you can attach the winch to that when needed. That gives greater flexibiltiy as you can attach to the front or rear then.
I wonder as to how much pull that hitch receiver can withstand. Thanks for the response. I was really hoping there would be enough room on top of the bumper even if i had to cut the brush guard to fit a winch. Thanks again ill keep looking for one that looks good and i can afford.
I bet if you gave Ranchhand a call, they could give you some more info on how much weight the front hitch can handle. The bumper will be attached directly to the frame so it wouldn't be the limiting factor.
Hidden Hitch rating = 9000 lbs pull
The rating for Draw-Tite's front receiver is 9000 lb max winch line pull. Hidden Hitch and Reese are owned by the same company and should be the same rating. I believe they are all actually on the same Towing Products drawing, just with different part numbers.
Pics of mine in my gallery - no winch yet, though.
