How to tell if it has limited slip?
Old May 10, 2007 | 04:54 PM
Cyprex's Avatar
If a F150 has the LS from the factory, will it be listed inside the drivers side door?
Found 2 nice 05 Scab's I'm going to go look at this weekend.
Old May 10, 2007 | 05:03 PM
NASSTY's Avatar
19 — 3.55 open diff.
26 — 3.73 open diff.
B6 — 3.73 limited slip
H9 — 3.55 limited slip
Old May 10, 2007 | 05:08 PM
Cyprex's Avatar
Thanks!
Edit, leaving this link here if this is searched.
http://www.ford-trucks.com/article/i...r_Decoder.html
Old May 11, 2007 | 02:45 PM
Sackett's Avatar
Aside from checking the codes, the fastest way to tell is take the truck to a patch of grass, stop, then floor it and see if you left one or two tire marks.
Old May 11, 2007 | 02:53 PM
Josiah's Avatar
Jack up the rear, spin one tire by hand and depending on the direction of the other tires rotation...that will tell us if you're running an LS or stronger back there.
Old May 11, 2007 | 03:12 PM
NASSTY's Avatar
Just do a big smokey burnout and hope nothing breaks.
Old May 11, 2007 | 03:22 PM
Tylus's Avatar
if gas + gravel or grass = 2 tire marks, proof it's got a LS
if gas + gravel or grass = 1 tire mark, well IMO, don't buy the truck
Old May 11, 2007 | 03:26 PM
BestNTx's Avatar
Powerbrake it
Old May 11, 2007 | 04:13 PM
Tylus's Avatar
that gets expensive, and most dealers have real issues with powerbraking
Old May 11, 2007 | 10:13 PM
Tbird69's Avatar
Wheels rotate in the same direction=LS
Wheels turn in opposite directions=open diff
