The Boss Engine
Old May 2, 2007 | 08:05 AM
4xford1's Avatar
Originally Posted by SuperSport1985
WOW that sucks I kill Hemis left and right and then the speed limiter hits and I hate that, as far as Tundras what the hell are those things?????
Well I dont have a supercharger.......... Stock for stock the hemi and tundra will kick or a$$.
Old May 2, 2007 | 11:50 AM
RED WING NUT's Avatar
Originally Posted by BeyondLimitz
...produce more than 425 hp (317 kW) and 425 ft·lbf (576 N·m)... ...and get 10 mpg...
Old May 2, 2007 | 12:47 PM
masterd's Avatar
Sure... even if Ford does put out the 6.2l BOSS engine and a 5 or 6 speed auto... How do WE know that it is really going to help us out?! The way Ford rigs some of the powertrain components you will see 400 engine hp out of the BOSS and only 250 hp to the ground... the rest will be ate up by drivetrain loss. So even though you might get a 6 speed auto... how refined is it going to be?
Totally true
Old May 2, 2007 | 04:30 PM
Tylus's Avatar
a 6 speed to get better mpg...it will be nice, but I don't think we'll see an earthshaking difference. probly about 1-2 mpg on average.
what that 6 speed will do is improve the over-all driveability of the truck. instead of 3 power fwd gears, you will now have 5 power fwd gears. the final output ratio for 6th will be roughly the same as our current 4th gear is, maybe a little lower.
those 5 gears will allow for deeper gearing and let us better utilize the power of the 4.6/5.4/6.2 I can foresee alot of fun. also, we might see the tow ratings go up. ~10,000 lbs for a 1/2 ton is alot already though.
Old May 2, 2007 | 06:40 PM
jmt0645's Avatar
It will only be 4 power fwd gears with 2 overdrive gears. but its still better than what we have.
Old May 2, 2007 | 10:19 PM
Tylus's Avatar
2 O/D's...that seems weird...I'd have thought it would follow the 6 speed manuals...oh well
Why can't Ford put out some #'s and a firm production date.
Old May 2, 2007 | 10:56 PM
Droog's Avatar
The Dodge Ram 5 speeds are three forward gears and two overdrives. When you select tow/haul it locks out both overdrives.
Old May 2, 2007 | 11:05 PM
Black3v's Avatar
Originally Posted by birddog_61
From what I understand the Boss is not a mod motor.
Blake
It is going to be a modular motor design still just with larger bore spacing, hence a completely new block. The reason being with the current bore spacing the bores cannot be made much larger safely and we all know there is no replacement for displacement! This is also why there are rumors of a much larger (around 7 liters) variant of this new motor in special addition form most likely but hey its just rumors. Finally a production mod motor with more than 330ci (besides the V10).
Old May 3, 2007 | 07:04 AM
MGDfan's Avatar
Not wierd at all.
The new Expy 6-speed has 2 OD's; (0.86:1 & 0.69:1). and a first gear of 4.17:1(!). Nothing new here. With that tranny alone, a 3.73:1 rear gear, and the existing 300HP 5.4 3V, it allows the Expy to more than hold it's own against a 4-speed equipped new 6.0 L Chebbie - both in accel and especially in towing. With the BOSS - it wil be stunning.
They're just ratios... and allows the use of a 4:10 or better rear end.
Best of both worlds, nice tq multiplication in the lower gears & low rpms at cruise.
Old May 3, 2007 | 06:42 PM
enormous's Avatar
Windsor Engine Plant, home of the 5.4 3V has been running some prototype 5.4 3V for the 2009 model. I saw it on the Plant build sheets.
Old May 3, 2007 | 07:29 PM
weazel's Avatar
Registered User
i think its either gonna be
1) 5.4L 4V 6 Speed Tranny
2)5.4L 3V 6 Speed Tranny (i think it will be this) If you notice the F150 tends to fallows what the Expy gets...
Old May 3, 2007 | 10:40 PM
MGDfan's Avatar
That's unfortunate. I don't think the buying public is going to continue to tolerate a displacement disadvantage with the same CID that's been in there for 10 years. Not with everyone else bumping up their mills.
Cubes sells.
Old May 3, 2007 | 10:44 PM
FX4REACTION1's Avatar
I dont mean to change the subject BL but you arent really in Beyond Limitz are you?
Old May 4, 2007 | 11:41 AM
Netduke's Avatar
are you talking about the new BOSS crate engines or some other engine?
http://www.fordracingparts.com/announcements/news48.asp
the boss crate engines are already for sale...
Old May 4, 2007 | 12:06 PM
Tylus's Avatar
no, that's for the Boss 302...great application for Mustangs, but the F-150 is supposed to get a 6.2L Boss motor
