MY A/C doesn't feel that cold.
Old Apr 30, 2007 | 03:03 PM
ThumperMX113's Avatar
I dont know. My A/C was undercharged from the factory by a couple of pounds and now it blows nice and cold!
Old Apr 30, 2007 | 03:09 PM
weazel's Avatar
Registered User
yea my air sucks, in my old 2001 screw, i would freeze on high, i put my 06 on high at 60 degress doesn feel like anything.. i hate it..
Old Apr 30, 2007 | 04:17 PM
azmidget91's Avatar
here is a link to the actual efans
http://www.jusnesmodified.com/store/...products_id=85
like i said this is the cheapest i have found them and have had them on for almost a year now with no problems, and freezing cold a/c, btw when i cruze with the windows down in 100+ degree heat i have the ac on and wearing sandles my feet get too cold and i have to turn it off
Old Apr 30, 2007 | 08:20 PM
deapee's Avatar
bam, if you're thinking of 'upgrading' to the AC system I have, save your money. It can't be any better than what you have, trust me.
But now that you all mention it, I might just have them check it at the dealer to make sure it's charged up all the way.
Old Apr 30, 2007 | 08:21 PM
Quintin's Avatar
Originally Posted by bamorris2
Is it reasonably possible to retrofit a 2005 with the newer/better system? What would be involved? How much $$$ would we be looking at?
Haven't a clue. I plan on finding out though if/when I ever have to replace my evaporator.
Old Apr 30, 2007 | 11:39 PM
ChadS98GT's Avatar
thanks for the link....that looks good...now just to find $315
Old May 1, 2007 | 12:19 AM
RamSS/T's Avatar
Mine too...I added a can of freon and it has been ice cold ever since. I think that would fix 99% of the complaints in this thread.
Old May 1, 2007 | 12:22 AM
I was exactly a can low too, cost cutting measures at its finest! I don't think we need any upgraded A/C components, just the right amount of freon!
Old May 1, 2007 | 10:08 AM
Quintin's Avatar
Don't go indiscriminately adding refrigerant...an overcharged system won't cool any better than an undercharged one.
Old May 1, 2007 | 01:42 PM
NCSU_05_FX4's Avatar
Any way to check refrigerant levels without having to go to the dealer?
- NCSU
Old May 1, 2007 | 01:58 PM
beckerjs's Avatar
- NCSU
x2
I have the right gauges but I don't know what pressures are on the 134 systems
Old May 1, 2007 | 02:38 PM
sysman_rick's Avatar
Post
If you have a meat thermometer,put in in/on one of the vents. Should het 55-65 degree air on recirculate.
Old May 1, 2007 | 02:58 PM
tbre's Avatar
Had the same problem, first trip to the dealer the system was low on freon. The second time the front seal on the compressor was bad. Since then the AC works real good.
Old May 1, 2007 | 03:26 PM
beckerjs's Avatar
at what outside temp? 55-65 is a large margin for error
Old May 1, 2007 | 03:34 PM
Gipraw's Avatar
I have been plagued by a non functioning AC since I bought my truck last July ..
If I turn the truck off with the AC still on .. it takes two or three times to cycle the switch off, then on to get the compressor to kick back on .. Took it to the dealer in August .. the acknowledged the problem, and were able to recreate it .. they told me ford was aware fo the issue, and would have a fix for it in November/December .. I am still waiting on that fix .. it really sucks, because I can't ever use AUTO, and sometimes I have to sit for 4 or 5 minutes, or shut the truck off and restart it to get the AC to work ..
lots of fun in Houston, I tell ya ..
the supposedly checked the charge, and all the seals, and everything was fine there.
It sucks .. because the AC in my 2006 Five Hundred will freeze you out in about 5 minutes
