Taller Block or Add-a-Leaf
Procomp sags in the rear
I couldn't believe how much mine was off after I installed the Procomp lift. I thought I'd done something wrong! In any case, I installed some 4" add-a-leafs to the rear w/out changing the block the kit came with and now it sits almost level. It's close enough that I can't tell w/out measuring and it looks a lot better.
axle wrap : caused by torque of the rear wheels twisting the leaf springs into a sort of "S" shape. This is unwanted suspension movement that allows the pinion angle to change.The springs twist and untwist rapidly, causing the rear to hop under power. Spring-over axle leaf setups are more prone to axle wrap than spring-under configurations. Shock placement, such as one shock facing forward and one facing backwords, is done to reduce wrap. Axle wrap is also increased by lift blocks. Here is a simple diagram showing the leaf twisting under axle wrap.
Sorry guys but I'm running a 5" block, 2" Deaver add-a-leaf, a few performance mods and no axle wrap. Springs are better than blocks, but these trucks arn't a offroad monster so I wouldn't worry about it but that's my opinion. . not to mention my truck goes offroad almost every day including pulling a 6,000 lbs trailer out of sugar sand.
Are you sure? ProComp's 6" lifts advise stacking their 2.5" block with the factory 2" block, I didn't think they'd sell a kit that would be illegal in a lot of states.
Originally Posted by Zaairman
Blocks lead to axle wrap, axle hop, and broken/warped springs. And stacking blocks is illegal in most states, and very dangerous. Get the AAL.
I'm sure you're getting axle wrap. Ever done a burn-out and been rewarded with a hopping axle? That's axle wrap. It happened in my F-150 many times
I'm sure I'll have some with a set of 4.88s though! I'm planning on a set of traction bars though, I haven't decided what to get yet though, I might take up the task of building a set.The only vehicle I've ever got wheel hop in other than my Mustang, which was only once, was my pops 2002 F-250 on the beach. My truck, never. Central Florida has some pretty wicked sugar sand too.
Didn't have much time to search, but from what I've heard, any blocks on the front end is illegal (and very unsafe), and stacking blocks is also illegal. A few states even have laws against blocks... Lift laws...
Procomp lift & blocks
. . don't they only include a 2-1/2" block in their kit?
I'm pretty sure other members don't me that the instructions or ProComp's tech support told them to stack it with their factory block for a level stance.
In any case, I just used the supplied block and used a 4" AAL. Now that I'm thinking about it, maybe the difference is that my truck is 2WD. I didn't have any existing blocks.
hey cstamper can i see a pic of your truck please cause mine is 2wd also. I would also like to know what brand aal you installed, and would like to hear feedback on some brands and heights of aal people think i need to get level.
