Want the Fastest New Body style?
Old Apr 25, 2007 | 07:51 AM
  #31
Smok][n's Avatar
Originally Posted by 05RoushMarkLT
My curve was actually consitent with Whipples, but we hit the speed limiter, so it stopped. If we could of gotten to the same RPM's, I would of been around the mid 370 range. That sounded about right being that I was a supercrew, 4X4 and have 22" wheels. They were 2wd, extended cab and stock wheels/tires. Pretty much everybody that I saw with the stock whipple tune had the same issue and was in the same range. Whipple said they had the speed limiter off when they did their dyno run, so the advertised numbers aren't obtainable unless they turn it off.
Have you checked your plugs lately? Maybe the dealership can hook their equipment up and see if there are any issues. That's how I found out about my plugs being bad.
gotcha. i had the speed limiter when i was on the dyno too. they said that they would try it in 2nd instead of 3rd gear. i originally thought that being in any other gear besides the 1:1 gear would yield inaccurate results, but ive since heard that it doesnt matter...
once i get my tune im going to try to identify and address the CEL's one at a time. the plugs could be one issue...
Originally Posted by MrSquirrel
oh and SMOKIN you do beat the stock hemi's right?
of course
Old Apr 25, 2007 | 12:15 PM
  #32
05RoushMarkLT's Avatar
Originally Posted by weazel
hey i wanted to ask you about the shift firmness they provide.. is it good or does it need more? also did you do any tranny work to help with the extra power?
The shifts felt good from stock. They are pretty firm now with the extra power now though. I don't recall Whipple adjusting the shift firmness though, so I wonder if the truck has started doing that over time.
Aside from swapping out the gears, I haven't done any other tranny/driveline mods.
Old Apr 25, 2007 | 04:42 PM
  #33
Tylus's Avatar
#5 person, my plan is working
should make that #6...and I like the one on the quad.
If you go with the stock tune, you will probably see numbers around the 330-340 range. The gears should compensate for the larger tires, so I'd think you would be right in there with the average numbers.
the thought of 400 ish RWHP actually kinda scares me. I do enough stupid things in my truck right now. Thats why I went and bought my Mustang. Truck was killin me with the gas mileage and my lead foot.
