37s with 2.5 as ?
37s with 2.5 as ?
im trying to put some 37s with no lift at all just the spacer .......
but im also planning on putting some new front fenders
http://www.glassworksunlimited.com/s...7&cat=2&page=1
those to be exact
and a new bumper
http://cgi.ebay.com/ebaymotors/ws/eB..._promot_widget
will the fenders being 3 inchs higher and wider help me clear 37s in front ?
and will the stock rear clear 37s?
just wondering i wanna try and get some stuff ordered my tires are starting to bald up............
also what kinda backspacing would i need to clear a set of 37x13.5 inch tire ?
i was looking at american racing teflon rims.. 4.35 sound ok?
those to be exact
and a new bumper
5.5 backspacing means i got more rim going into the truck right? wouldnt less bs help those tires clear the control arms and what not? i have no clue to this bs stuff ........
I like the parts that you are putting on, but I think that you need to get a little more lift to look really good. I saw a 04 Scab a long time ago in Truckin' magazine called "Tonka", I think that was the name, that was set up basically like what you are wanting to do. I believe that it had 38's and was on the stock suspension w/crazy cut out fenders to clear the meats. You may want to try and see if you can find a picture of that truck to see if you like the way that it looks b/f you get too far ahead of yourself.
i think it will look pretty tight
pre runners look jsut like that...on 37" tires but look at stock height.
yea the tonka truck was like that....but his will be a little different and better IMO
Originally Posted by extremeethan
Whhhattt!!! Am I then only one to think that bumper looks like an old train cattle guard??
well i dont wanna lift it......since tire size is your clearance.......lift is just to get bigger tires to get more clearance......and i dont want to spend 2500 on a lift when i can get all this stuff to get same clearance as a 8 or 10 inch lift................. but i dunno id like to find a diffrent bumper maybe prerunner style or something that was one i liked for price atleast
I think it will probably work and look really good. However, I don't like that bumper at all. I would get a prerunner bumper like the on one on the Glassworks Unlimited web site. You can also get a full inch of flare in the rear by having a custom rod made to push out the rear fenders, JD Fabrication does this all the time.
. . you're still just using factory shocks and a spacer for suspension, it's not like you're doing Kings, hydraulic bump stops, limiting straps, or anything to achieve better suspension action. It's kind of gay, don't half *** it. If you don't like what I say than just ignore it.
