cam upgrades!?
Originally Posted by BHf150
I put stage two cams on my truck Not much noise at idle like you would think,I feel more power at top end The cams are about 900 bucks
Its hard to say if i lost any power at low end because i have 4.88 gears,Iam having problems with the new motor because of the touqre convertor ,The cams are nice at the dyno but the truck made no power because of the touqre convertor
Originally Posted by Josiah
I only consider the Stage 4's but I'd like to see how rough were talkin. If it's anything like the video in hllon4whls's sig, I'll be ok like it is. Believe it or not my truck is relatively quiet for the setup on the highway.
Of course that cam will not work well in an EFI motor. that cam is .540 lift and 285 gross duration. Pushrod ford cams have a lot of lift. That is basically the largest hydraulic flat tappet cam that lunati makes for a small block.
