Tranny Tempature?
Old Apr 4, 2007 | 07:26 PM
FX4REACTION1's Avatar
Tranny Tempature?
What should our trannys be running at? And whats the Highest Temp. they should be at last night I noticed that mine hit 146 dont know if that high or not?
Old Apr 4, 2007 | 07:33 PM
weazel's Avatar
Registered User
doesnt sound like it...
Old Apr 4, 2007 | 07:36 PM
kd4crs's Avatar
Mine runs 150-160 degrees F during normal driving, not towing.
Old Apr 4, 2007 | 07:46 PM
04procompLARIAT's Avatar
When I am towing mine usually get around 190-200...normal driving hovers around 150-160.
Old Apr 4, 2007 | 07:51 PM
Bootleg837's Avatar
In livelink with a Xcal2 my trans temp is 333 to 382
Old Apr 4, 2007 | 07:53 PM
kd4crs's Avatar
If your trans is really that hot it will not be around long.
Old Apr 4, 2007 | 07:56 PM
ThumperMX113's Avatar
Normally mine sits about 180 degrees in Florida heat, stop & go traffic. I have had it up to 205 degrees coming back from Miami on I95 but it was hot and I wasn't doing the speed limit.
. . I agree!!
Old Apr 4, 2007 | 08:20 PM
Quintin's Avatar
Bad things happen to automatics when they're run above 260 degrees or so for an extended time.
At 300+, the friction linings will turn into kitty hair in short order.
Old Apr 4, 2007 | 10:25 PM
Oxlander's Avatar
My transmission runs between 144 - 155 during normal driving and has been as high as 195 while towing. I think your 146 is about right. Do you have the factory tow option with the transmission cooler?
ox
Old Apr 4, 2007 | 10:38 PM
MGDfan's Avatar
Discussed up the wazoo already .... some good readin' here:
https://www.f150online.com/forums/sh...9&postcount=36
Old Apr 4, 2007 | 10:56 PM
ROBFX4's Avatar
Mine is a steady 142, stop and go traffic is drops off a bit, but if i got my foot in it driving like an idiot it might pop up closer to 150-160. At 220-230 (i think it might be even higher, dont remember exact number) or so you should get your high trans temp warning that will put the engine in "limp mode". When i desroyed my valve body i pegged out to 250 trying to get the truck home, which gave the truck a nice burnt smell for a couple days.
Old Apr 4, 2007 | 11:19 PM
SuperSport1985's Avatar
My trans temp reading is coming from the "test port" and when its cold up here in Illinois its halfway between 100 and 150 normal driving 150 hauling *** 180 and yes it does have a cooler. But doesn't it also affect where the temp reading is beign acquired from? At 300 degrees I would say that tranny is cooked.
Old Apr 4, 2007 | 11:43 PM
ox
Yes mine has the transmission cooler and the tow option.
Old Apr 4, 2007 | 11:44 PM
Just started the thread after getting home, thanks for the link
Old Apr 5, 2007 | 09:02 AM
. . by the way, I don't even think the transmission cooler kicks on until it reaches around 210-230 degrees.
