Got 4 plugs changed without a problem.
Old Mar 23, 2007 | 10:50 AM
FATHERFORD's Avatar
I hate them plugs...
A socket, a vice, and cotter pin is a cheap way to gap the plugs. Instead of buying the tool.
Old Mar 23, 2007 | 11:51 AM
Satstalker's Avatar
There is a TSB out on how to remove these plugs. I have read it but have not grow-en the ***** to tackle it yet. It also says to put nickel anti-seize on the end of the plug where the carbon builds up.
Here is the copy and paste of the TSB. Unfortunatly the pictures dont show. If anybody wants the TSB in PDF format give me your email address and i will send it to you.
FORD: 2004-2005 F-150
2005 Expedition, F-Super Duty
LINCOLN: 2005 Navigator
This article supersedes TSB 06-5-9 to update the vehicle lines and model years.
ISSUE:
Some 2004-2005 F-150 and 2005 F-Super Duty, Expedition, and Navigator vehicles with a 5.4L 3-valve engine may experience difficulty with spark plug removal which may cause damage to the spark plug and leave part of the spark plug in the cylinder head.
ACTION:
Refer to the following Service Procedure for techniques to remove the spark plugs and extract broken spark plugs.
SERVICE PROCEDURE
General Spark Plug Removal
To remove spark plugs without damage, it is necessary to adhere exactly to this procedure before removal is attempted.
Make sure the engine is warm (hand touch after cooling down).
CAUTION: DO NOT REMOVE PLUGS WHEN THE ENGINE IS EXTREMELY HOT OR COLD SOAKED. THIS INCREASES THE CHANCE THE THREADS COULD BE DAMAGED.
CAUTION: BE SURE TO WEAR SAFETY GLASSES FOR STEP 2.
Remove the coil-on-plug assemblies and thoroughly blow out the spark plug wells and surrounding valve cover area with compressed air.
Back out the spark plugs, no more than 1/8 to 1/4 of a turn. Apply penetrating oil (AeroKroil or equivalent) and fill the spark plug well just above where the jamb nut hex sits. A minimum period of 5 to 10 minutes of soak time is required. The penetrating oil will wick down to the ground electrode shield in this time. DO NOT WORK the spark plug back and forth at this point.
CAUTION: EXCESSIVE PENETRANT, OR REPEATING THE PROCESS SEVERAL TIMES WITH TOO MUCH FLUID, COULD INTRODUCE ENOUGH LIQUID VOLUME TO HYDRO-LOCK THE ENGINE.
CAUTION: DO NOT USE AIR OR POWER TOOLS FOR PLUG REMOVAL. THE PLUG MUST ONLY BE REMOVED WITH HAND TOOLS.
Slowly turn the spark plug out. Some screeching and high effort may be noticed but, not in every case. The expected removal torque is about 33 lb-ft (45 N-m) but should decrease on the way out. If it is higher, try turning the spark plug back in a half turn, then back out again. If the turning torque still seems high, repeat the back and forth rotation along with some penetrating oil to reduce turning effort.
Separated/Broken Spark Plug Removal
If the plug does come apart even after following the General Spark Plug Removal Procedure, it will break in one of two modes:
Mode 1: The ground electrode shield is left behind as an empty shell (Figure 1).
Figure 1 - Article 06-15-2
Mode 2: The porcelain center and ground electrode shield is left behind and only the upper jamb nut comes out. In this case more soaking is required and long-reach nose pliers should be used to grasp and remove the porcelain center from the ground electrode shield (Figure 2).
Figure 2 - Article 06-15-2
Once there is only an empty ground electrode shield left in the cylinder head, perform the following steps to remove the shield using Rotunda Special Service Tool 303-1203 (Figure 3).
Figure 3 - Article 06-15-2
NOTE: THIS TOOL IS ONLY DESIGNED TO WORK WITH AN EMPTY GROUND ELECTRODE SHIELD. IF THE SPARK PLUG CAME APART IN MODE 2, THE PORCELAIN CENTER MUST BE REMOVED PRIOR TO FOLLOWING THESE STEPS.
The combustion chamber must be protected from contamination during the extraction process by using a modified vacuum cap (382444-S) as a stopper-type plug. This is because the remaining ground electrode shield will be thread-tapped, so the cap is needed to prevent thread chips from falling into the cylinder bore. Cut a vacuum cap to a 3/8" (10 mm) length for each ground electrode shield that needs to be removed.
Install the modified cap with a long drill bit or suitable wire (Figure 4), sized for the internal diameter of the cap. The rubber cap should bottom-out on the electrode strap of the ground electrode shield once installed.
Figure 4 - Article 06-15-2
Thread-tap the ground electrode shield using a 9.0 x 1.0 mm "plug" tap (tap profile is about 3-4 reduced diameter threads on the tip end).
Coat the end of the tap with general purpose grease as shown in Figure 5.
Old Mar 23, 2007 | 11:52 AM
Satstalker's Avatar
Second part of TSB.
Figure 5 - Article 06-15-2
Turn the tap about 3 to 4 turns into the ground electrode shield once the tap begins to cut. As the shield is tapped, for every 1/2 turn, the tap should be backed up 1/8 turn to "break chips" and prevent any cut material from coiling-up and laying in the spark plug well. All of the thread chips will embed in the grease pack or drop inside the vacuum cap when following this procedure. A suitably sized tap wrench of about 7-9 inches in handle length will aid in reaching down the well. If not available, use an 8 point socket with a ratchet and drive extension. Keep the shank aligned with the axis of the spark plug bore cavity to prevent possible thread bore damage. Use care not to damage any spark plug threads on the way in.
CAUTION: DO NOT ATTEMPT TO REMOVE THE GROUND ELECTRODE SHIELD WITH THE TAP AND WRENCH. THE TAP MAY BREAK IF THIS IS ATTEMPTED.
Carefully back out the tap while maintaining the residual grease coat on the tap which contains some chips. Take care not to touch the sides of the spark plug well bore during removal.
Once the ground electrode shield is tapped, thread Rotunda Special Service Tool 303-1203 into the ground electrode shield to extract it from the spark plug well and encapsulate any remaining chips from falling into the combustion chamber.
NOTE: SEE FIGURE 6 FOR DETAILS OF THE TOOL AS INSTALLED IN THE HEAD.
Figure 6 - Article 06-15-2
Install the stepped end of the tool pilot bushing into the spark plug well ensuring it bottoms out.
Screw the center shank into the ground electrode shield. Do not over tighten the shank, to prevent thread stripping.
Install the nylon washer and jack nut until finger tight.
Turn the jack nut with a socket and 3/8" drive ratchet until the ground electrode is freed from the cavity and withdraw the tool assembly. Several turns of the nut are required. Upon removal, any remaining chips not caught earlier by the tap grease will be captured by the rubber plug sitting at the bottom of the ground electrode shield.
NOTE: ONCE THE SPARK PLUGS HAVE ALL BEEN REMOVED, NEW PLUGS SHOULD BE INSTALLED USING A FILM COATING OF MOTORCRAFT HIGH TEMPERATURE NICKEL ANTI-SEIZE LUBRICANT (XL-2) ON THE GROUND ELECTRODE SHIELD OF THE NEW SPARK PLUG (FIGURE 7). DO NOT COAT THE ELECTRODE STRAP OR THE PLUG WILL MISFIRE. THE NEW PLUGS SHOULD BE INSTALLED WITH NO LUBRICANT ON THE THREADS AND TORQUED TO SPECIFICATION, 25 LB-FT (34 N-m).
Figure 7 - Article 06-15-2
PART NUMBER PART NAME
AeroKroil Obtain through www.kanolabs.com or by calling 1-800-311-3374 (orange aerosol can)
382444-S Vacuum Cap
XL-2 Motorcraft High Temperature Nickel Anti-Seize Lubricant
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage And Emissions Warranty Coverage
OPERATION DESCRIPTION TIME
MT061502 Claim Labor As Actual Time Actual Time
DEALER CODING
BASIC PART NO. CONDITION CODE
12405 01
Old Mar 23, 2007 | 12:12 PM
YOMAN's Avatar
Yikes..
I cleaned my 8 plugs at 25K and is now passing 35,500.
I was planning to change all 8 sparks sometime this late spring.
I would suggest you all to do is use air compressor to blow all sands dirty etc inside the hole (after remove the coil plug) by air blow to aviod get dirty into the hole after sparks out.
My question, After PB into the holes, after you took sparks all out, how to get pb out of there? rag clean or let it burn itself after install new 8 sparks?
Thanks!
YOMAN!
Old Mar 23, 2007 | 01:02 PM
khendrix2374's Avatar
Originally Posted by Matt 05'FX4
I took 2 of em out the other day and I found that unscewing them til there was a good bit of resistance and then running them back in for another go made a lot of difference. After about 2 out and back in, they came out a lot easier. I guess it breaks the carbon up that's below the seat a little better or something.
Good call. I did the same thing myself on most of the plugs. Kind of like tapping a new hole... screw the tap in a little bit and back it out.. little further.. back it out.
I didn't. After putting in new plugs in one head, i started the truck up... a decent amount of blue smoke rolled out for about a second. The PB burned off. I figured the worst that could happen would be a little damage to the Cats... o well.
Old Mar 23, 2007 | 02:10 PM
rdalley's Avatar
Can someone tell me the importance of using the nickel anti seize compared to standard anti-seize? I have some regular Permatex anti-seize. Will that damage anything if I use it instead of the nickel on my plugs?
Old Mar 23, 2007 | 04:40 PM
enormous's Avatar
Congrats at getting those plugs out, some research and common sense certainly helps.
Norm
Old Mar 23, 2007 | 05:41 PM
Req's Avatar
Req
When I first got my new '04, 5.4 3V, I didn't think anything about plugs, except I wanted a new set on hand when I was in the mood to change. I used to change my Fords since 1970 every 15K miles. On my '04 I pulled the #5 (front drivers side) and holy cow, what a plug as I had never seen. It came out OK and I put it back. When I asked for a set of plugs over the counter even the parts clerk appeared sheepish at the cost of the new plugs. At the time I passed @ $9.00 per plug.
Since then from two Ford Web sites I have read approx 400 postings about the risk of taking out plugs, Dealers reluctance to reimburse for pulling heads, owners who (with luck) pull plugs in a breeze, and the unlucky ones that snap off plugs while doing self maintenace. This has convinced me to let my rig go to 60K miles, then sell it. "Maybe" is not the word I want to use when doing common maintenance on my vehicle.
My Son-I-L just had his Ford '02 CrewCab T-boned and totaled. He had the 4.6 engine. I advised him of the plug problem with the 5.4 and that I was selling at 60K. This caused my Son-I-L to want to take a look at the new, bigger Toyota. I never thought I would concur with owning a Japanese noodle. But when common maintenance is a hope and maybe type of situation it is time to consider alternates.
Ford is not only losing money in the market, but they are laying down on the job by allowing a huge maintenance problem to go unaddressed with the 5.4, 3V plugs. Ford may have the TSB 06-5-9, tools TB-8489-A, TB-8490-A,TB-8493-A, TB-8491-A, TB-8492-A, and TB8494-A, but Ford does not have any guarantee that a plug will not break and cause the owner headaches to no end to his time and wallet.
