Project: Fire/ Rescue F-150
Old Mar 23, 2007 | 08:38 AM
Copperhead64's Avatar
Sounds like a major project and i agree with 2stroked about taking your time and planning things out. My friend is a Miami Dade fire fighter and i told him about this and he's envious since they wont allow him to use his F250 that way. He did put on a toolbox, Cb radio with loudspeaker, and strobes anyway.
But here's my question to everyone else;
Does anyone think he should add another battery with all that equipment or maybe an Optima Deep Cycle battery could hold up with it?
Old Mar 23, 2007 | 08:42 AM
MGDfan's Avatar
Yup.
Big battery & a high capacity alternator. Think of it as a really big audio install - oversize the electrical & reliability will follow.
Old Mar 23, 2007 | 09:23 AM
Copeland!'s Avatar
Originally Posted by 2stroked
If you're asking for advice, the first thing I'd suggest is taking a giant step backwards. The placement and mounting of stuff is important, but in my experience, the more important thing is having an overall plan with an install this complicated. What I would start with is a list of equipment that inculdes power consumption and special requirements such as "switched with the ignition or always hot." Although you're using all LED lighting (and they have a very low current draw), you want to know how much juice you're going to need so you can size wiring, relays, fuses, etc. properly. Once you have that, you can start looking for ways to route the wiring and places to mount stuff. Believe me, when I started poking around my '05 looking for locations, I had to change a number of my plans. Good luck!
That is a great piece of advice and I have already taken all of that into consideration. I will have some help from an electrician, a few other firefighters, and electrical engineer, and hopefully I will make a friend in the service department at my local ford dealer.
As for the need for a bigger alternator, I don't believe it will be necessary due to the fact that most of the above products listed require very little power. An optima red or yellow top battery however is a great idea.
Old Mar 23, 2007 | 10:14 AM
HHIFX4's Avatar
You might want to consider a Warn Trans4mer grill, thats what all of our F150's have on them, also we secure everything with a small weld on the bottom of the nut so that you cant just unscrew everything and steal it
Old Mar 23, 2007 | 10:17 AM
texaspyro21's Avatar
Loctite everything that bolts on. Get the permanant stuff as it helps prevent theft; Its not permanant, but won't come undone without a lot of force or a lot of heat.
Old Mar 23, 2007 | 10:53 AM
Copeland!'s Avatar
Good idea's. The question still remains however on if the speakers should be mounted behind the grill or on the grille guard.
Old Mar 23, 2007 | 11:17 AM
HHIFX4's Avatar
we mount ours on the grill gaurd
Old Mar 23, 2007 | 12:42 PM
guitarman502's Avatar
awesome man! I'm a volunteer fire fighter from WV. Good Luck!
Old Mar 23, 2007 | 06:52 PM
chief40al's Avatar
What is a jotto desk?
Old Mar 23, 2007 | 11:26 PM
Copeland!'s Avatar
Old Mar 24, 2007 | 07:30 PM
HCFR-Halligan's Avatar
Just to clarify, this will be for responding only? or is the truck gonna be used in operations? Depending on what kind of equipment you guys respond with Id Also recomend a winch, maybe a way to mount SCBA and how about an electric Federal Q.
Old Mar 25, 2007 | 12:56 AM
Copeland!'s Avatar
Old Mar 25, 2007 | 12:59 AM
Budha05STX's Avatar
Good luck on the truck.
What part of B.C. do you tend to?
Old Mar 25, 2007 | 02:47 PM
Copeland!'s Avatar
North B.C.
Old Mar 27, 2007 | 08:22 AM
2stroked's Avatar
Didn't you forget somebody on your team, like your Banker? Sounds like a pretty expensive install to me. Good luck though - and post pictures when you're finished!
