Dry Out Tires?
Old Mar 22, 2007 | 01:48 AM
codywalker's Avatar
Dry Out Tires?
How the hell do I fix this, I used Macguiar's Hot wheel all wheel tire stuff.. and washed and scrubbed it. It dried and STILL looks like this. What gives?
Old Mar 22, 2007 | 02:03 AM
Smokie700's Avatar
From: now Afghanistan but normally Hawaii, Lousisana
get some wesleys blech white. That stuff is great on stubborn tire stains.
Old Mar 22, 2007 | 02:33 AM
weazel's Avatar
Registered User
scrub with soap and water, let try then use BLACK MAGIC: TIRE WET..... works great..
Old Mar 22, 2007 | 07:01 AM
ford141's Avatar
I use Tornado cleaner to clean off my tires, works wonders and is not as damaging to aluminum parts as bleach white. Your tire is not dried out, the brown is just dirt that stick to the tire shine. I also use a tire cleaner called Purple Passion that I get at Advance Auto that is cheaper than the Tornado but is also less aggressive. Either will work, but the Tornado will work better.
Old Mar 22, 2007 | 08:46 AM
slash123's Avatar
Do what he said. Your tires look like they are coated with break dust. The Wesley's will take that off and the you can apply tire dressing.
Old Mar 23, 2007 | 01:22 AM
ian51279's Avatar
I use Westley's Bleach White and a scrub brush. Works great.
