Transfer case motor
Old Mar 4, 2007 | 10:40 PM
5.4-FX4's Avatar
Transfer case motor
Well guys, tomorrow morning will be the 2nd time I take my truck into a dealership for a problem with my 4x4 system. the first time was last spring break.
the first time it was the transfer case motor (i guess the motor that engages the hubs). we'll see what it is tomorrow.
this is a bummer, as i have owned 5 Ford, four-wheel drive trucks, and this is the 1st one with ANY problems at all. it's not like i had been using the 4x4 system a lot, and i had been turning it on, on flat level dirt roads so that it would "oil" itself. i'm pissed really.
Old Mar 5, 2007 | 10:01 PM
5.4-FX4's Avatar
well, it's the transfer case motor again. have any of y'all had this problem so often?
Old Mar 5, 2007 | 10:43 PM
hllon4whls's Avatar
Just an FYI, the hubs are vacuum operated. The transfer case motor is on the transfer case, which is on the back of the tranmission. Follow the front driveshaft towards the rear and you will find the transfer case.
My 06 is fairly new and use my 4x4 just enough to keep it excercised and no issues. About 6000 miles. I have no snow, but I did some LIGHT offroading just to get things dirty and everything was fine.
Old Mar 6, 2007 | 11:31 AM
cndcowboy's Avatar
50K miles so far, I use 4x4 quite a bit and I have never had a problem with it up to this point.
Old Mar 6, 2007 | 09:06 PM
5.4-FX4's Avatar
gotcha', so what does this transfer case motor do?
Old Mar 6, 2007 | 09:27 PM
kd4crs's Avatar
The transfer case motor shifts the mechanical selector on the transfer case to engage 4X4 HI, 4X4LO, and 2WD.
