*** Soft Brake Pedal Resolved ***
  #91
Old 03-09-2007, 08:46 AM
FX4ME2's Avatar
I'm hoping to get my Rod adjusted this weekend.....
  #92
Old 03-10-2007, 05:37 PM
rms8's Avatar
Originally Posted by COLOKR
I would like to add my thanks to rms8 on this thread. I now have about 400 miles on the adjusted rod and have been ecstatic over the results. The fix was quick, easy, and free. More importantly, it works. We certainly could use more post like this. Thanks rms8, this is one of those annoyances that I can cross of my to do list.
  #93
Old 03-10-2007, 06:10 PM
miaf150's Avatar
Just did the brake fix on my 03 Lightning and WOW what a difference. That truck had the worse brakes ever...Night and Day. Will be adjusting the rod on my 06 SCREW tomorrow.
GREAT JOB RMS8...
Now if you could get my an additional 50-75 horses for 06 for free it would be greatly appreciated.
Thanks again,
  #94
Old 03-10-2007, 07:31 PM
rms8's Avatar
GREAT JOB RMS8...
Thanks again,
Sorry, no dice on the HP request....
  #95
Old 03-12-2007, 05:53 PM
rms8's Avatar
ttt
  #96
Old 03-12-2007, 11:36 PM
azfordby4's Avatar
I have noticed this in my truck. I am due for a brake job front and rear. If the spongy breaks continue I will give this a shot.
  #97
Old 03-13-2007, 12:22 AM
rms8's Avatar
Please keep in mind the post below...
Originally Posted by rms8
The rod adjustment is only advisable on a truck which had this condition from day one. In your case, adjusting the rod is only COMPENSATING (i.e., masking) for a completely different problem. You should have the braking system checked first before going the rod route, since, as I said, the rod adjustment is only a correct fix for the spongy brake pedal on a truck which had this condition from the very first day.
If the brakes on YOUR truck have progressively started doing this, then that is the result of some other issue and simply adjusting the rod would only mask the real problem.
  #98
Old 03-14-2007, 11:11 PM
ozcar2's Avatar
Is someone going to post some pics of what's involved with this adjustmnet?
  #99
Old 03-14-2007, 11:19 PM
D1G1T4L's Avatar
A nice tutorial with pics would be really nice for us challenged folks :o
  #100
Old 03-15-2007, 09:24 PM
Patatoe1's Avatar
Damn I had the whole post written, and then the server was too busy so it disapeared.
I went in for an oil change today and mentioned the soft brake pedal to the service manager. I told him about the actuator rod to set them on the right path. After an hour they came back, said they were done, and brought me on a test drive. The brake pedal was firmer, and the tech said he would show me how to do it when we got back to the dealer.
This is where things were different. His proceduer was loosely as follows.
Find the yellow "box" above the brake pedal, and unclip it
Move back the washer there
Now loosen/tighten there
Put back together, take for a ride and see if you like it
They didn't actually do anything inside the engine compartment, like I was led to believe they would have per the advice was given here.
  #101
Old 03-15-2007, 09:34 PM
Shane1's Avatar
HHHMmmmmm......
  #102
Old 03-15-2007, 10:14 PM
rms8's Avatar
So in a nutshell they shimmed your brake pedal??? Is that what they did?
  #103
Old 03-15-2007, 10:27 PM
Patatoe1's Avatar
What they did is pretty much what I posted. I'm not being short here. I don't have that much mechanical experience.
Check your e-mail
  #104
Old 03-15-2007, 10:44 PM
ozcar2's Avatar
Aren't there any Ford Techs on this board who can shed some light on this rod adjustment whole issue?
  #105
Old 03-15-2007, 11:35 PM
rms8's Avatar
Ozcar2,
No offense, but what more light needs to be shed on the rod adjustment? The “procedure”, however informal, is very straight forward. It has been explained (by those that have already done it) a few times in this thread. I have not done it to my F150 (the dealer did), but know full well how to, having done so on my Mustang.
You just remove the two nuts holding the MC on, then pull the MC forward enough so that you can turn the end of the rod which is revealed when the MC is pulled forward. Just a very small turn is all that is needed. There are a few more details elsewhere in this thread, but it’s really not a hard thing to do.
Quick Reply: *** Soft Brake Pedal Resolved ***
