where did you get your gears installed?
Old Feb 20, 2007 | 06:07 PM
purpony's Avatar
I was wondering all those that have had gear swaps... where have you had it done? where do i go about purchasing gears for both front and rear? what prices should i expect to pay?
I was planning on 35s with stock 3.73 gears... but would love 37s with 4.56s or something....
Old Feb 22, 2007 | 03:11 PM
purpony's Avatar
no one? i just talked to a ford dealer and they want $1585!!! just to do the rear!!!!!!!!!!!
Old Feb 22, 2007 | 04:38 PM
khendrix2374's Avatar
I had mine done locally by a guy that does rear-ends on the side. Took him 2 days to do the rear of my truck, but he did it all while the axle housing was on the truck with truck on ground.
Best I recall, I paid $180 for labor, roughly $300 for ring and pinion+ gear lube (he's a AMSoil dealer) and install kit.
Came out to about $550 best I recall. Search for Randy's ring and pinon locally.
Dunno what to tell you. Stealerships will rob your wallet.
Old Feb 23, 2007 | 04:23 PM
Josiah's Avatar
Just look around for gearsets on ebay, you can usually get a steal for someone who backed out of the install, like me.
I have 4.56's for the 9.75, min install kit. They are Yukon's, make an offer I can let them go cheap. They are brand new. It's missing a pinion seal which is about $20 at the dealership. Yukons are known to be the best but a hefty price comes with that.
I know I can get a good amount for these but I got a deal on them myself. They're in the classifieds.
Old Feb 23, 2007 | 05:13 PM
05RoushMarkLT's Avatar
I was quoted $1400 or so in Vegas for front and rear 4.56 gears installed. I came back to Alaska and paid $2000-2200 for 4.56 gears at the local Ford dealership. The local tranny and driveline shop quoted the same, so I went with the Ford dealership. Wish I would of picked them up in Vegas!
Shop around, but make sure you have a reputable shop do the install. Also, it might be worth it to check and see if they require you to buy the gears from them, or if you can bring in your own. They probably won't warranty them if you buy them from somebody else.
Old Feb 23, 2007 | 05:30 PM
charlie101's Avatar
4Wheelparts did mine
Old Feb 23, 2007 | 05:40 PM
BestNTx's Avatar
how much did they chare you? I've been thinking of going that route and were both in texas so it should be about the same price...
Old Feb 23, 2007 | 09:00 PM
purpony's Avatar
how do i know what my truck has for a rear-end? 9.75 or 10.25? Yukon has them listed for both
http://www.yukongear.com/DiffList.as...F150&Side=Rear
and the front is an 8.8? same as whats in the rear of my mustang?
but then they list an 8.8 for an 83-06 F-150 for the rear (is this for a V6?)
Old Feb 23, 2007 | 09:12 PM
ChrisAdams's Avatar
6 lug wheel with a 5.4 is the 9.75 rear. The 10.25 is seven lugs.
Or search for what 'rear axle number' in the forum. The vin code has been posted five or six times.
Chris
Old Feb 24, 2007 | 12:40 PM
5.4 litre has the 9.75"
for the 4wd.. the front has an 8.8"... *I think* it's a "reverse cut" gear set. somebody will correct me if im wrong.
Old Feb 24, 2007 | 02:02 PM
xplorgee's Avatar
How much do you think itll cost to put a LS in my truck. I know the LS is about 3-4 hundred. Just dont know how hard it is to install it.
Old Feb 27, 2007 | 04:10 PM
purpony's Avatar
i just got an email back from 4x4 shop somewhat close by, however i have never head of them and dont know anyone who has work done here...
this is what i was quoted....
FRT.Gear(your coice-Alloy,Genuine Gear,Superior) $236.16
INSATLL KIT: MANDATORY-W/ALUM.HOUS!!$104.10
RR Gear(Again your choice) $231.98
Insatll kit(Bearing and Seal damage upon removal) $171.60
Instalation per axle from us is $300.00
total of $1342
