does driveshaft need to be lengthened for Fabtech 6"?
Old Feb 15, 2007 | 09:32 AM
purpony's Avatar
I just purchased a 6" fabtech lift for my 04 supercrew.....
I was just looking around this site and someone mentioned that the driveshaft needed to be lengthened when using the 6" fabtech kit.....
is this true? Front or rear or both?
what if I use a front space and aal with the 6" for 7.5 or so " of lift... would it require lengthening then?
thanks all
Old Feb 15, 2007 | 09:39 AM
Whoodatt's Avatar
thanks all
You will be fine, no driveshaft work is needed.
Old Feb 15, 2007 | 11:34 AM
ThumperMX113's Avatar
Hmm, doesn't Fabtech make a driveshaft spacer?
Old Feb 15, 2007 | 02:52 PM
Ayresusn's Avatar
Yes, It comes with the kit. At least it came with my kit when I did my lift.
So ,No you don't need to legthen the driveshaft.
Old Feb 16, 2007 | 08:44 PM
djh1121's Avatar
Yep, spacer comes in the kit for the rear. No spacer needed for the front.
Old Mar 27, 2007 | 12:58 AM
fx4renegade's Avatar
you do need to index the front driveshaft
right in installation instructions
Old Mar 27, 2007 | 09:12 AM
KansasJoe's Avatar
You don't have to lengthen it but we always do because the driveshaft has to come out anyways to cut out the master spline and rebalance anyways. Think it ends up being 37". Costs about 120 and that's for master spline, rebalancing, new tubing and lengthening.
