Instrument Cluster Light Change
Old Feb 14, 2007 | 12:53 PM
Originally Posted by etrevino103186
sent
replied :santa:
hahah im gonna to start using this santa smiley more often
Old Feb 14, 2007 | 06:39 PM
zachespo's Avatar
Well Got back into it this after noon to mess with it some more. I went down to Pepboys and got some blue covers to put over the bulbs and i will see how that looks when it gets dark. But I did run into a little problem. I was trying to remove the coating on the back of the gear selector thing a really messed it up. It is a thinner piece of plastic and i ended up removing all of the paint. So right now I have a to guess what gear im in. Now i just gotta decide what im gonna do with that. Heres what it looks like. I just took a sharpie over to kinda cover it up.
I think that if im more careful removing the paint i should be able to leave the last layer of withe and take off the green.
Old Feb 14, 2007 | 11:13 PM
zachespo's Avatar
Well guys this is what I have now. Not exactly what i was hoping for but it is different. I will probably be wiring some leds to direct the light better but that won't happen for a little while.
Turned out to be more of a teal than blue. And you really cant see the needles.
Old Feb 14, 2007 | 11:21 PM
styxnpicks's Avatar
are the bulbs in the cluster LED's or regular bulbs?
Old Feb 14, 2007 | 11:23 PM
zachespo's Avatar
Right now I just have the regular bulbs with little blue covers over them. But I think im gonna get some leds to wire up and put in there.
Old Feb 14, 2007 | 11:45 PM
YellowFX4SCrew's Avatar
I got this from Moss. I like it with the red. I only wish that there was a way to make all of the lights on the radio and door panels/dash red also.
Old Feb 14, 2007 | 11:50 PM
zachespo's Avatar
You can change those but you have so take out the old LEDs and solder in new ones. I plan on doing that the same time I put the LEDs in the cluster.
I have seen those overlays before and thought they looked good but this was way cheaper.
Old May 4, 2009 | 01:34 PM
ZeroDormancy's Avatar
ive done EVERYTHING in the truck but the cluster which is now all over my table.
im snagged on the bulbs and the message center, i didnt know it took these bulbs i thought it would take the plcc-2 surface mount leds like everything else in the truck. no ive taken the whole thing apart just to see that i need to wait a week for the new bulbs to get here
Old May 4, 2009 | 08:54 PM
fomoco466's Avatar
check my pics
check out my pics, I've done several truck swaps, cluster and everything else.
Old May 4, 2009 | 10:45 PM
zachespo's Avatar
If all you are doing is changing the bulbs in the cluster it won't change anything cause the cluster has the green film on it. And from what iv;e heard from other people just changing to leds even just the white ones to keep the same green doesn't put out enough light to get everything lit evenly. Thats why i was planning on putting an led in for every tick mark or number but i ended up breaking that cluster. As it sits now everything is blue except the cluster and idk if im ever going to finish the project.
Old Sep 6, 2009 | 02:05 AM
Fabian06SC's Avatar
you wouldnt happen to have the actual xlt gauge FACE still laying around for a donor project would you?
I wanna do something with mine and need a template without having to take my entire cluster apart for an extended period.
Ill ship it right back to you unharmed once im done
