Did some Edge custom settings, how do they look?
Finally decided to play with my settings since I have been running the canned Level 3 for about 6m now. This is what I loaded up based off of other members settings that were posted. Let me know if they look straight, thanks.
5.4 running 93 Octane at sea level.
SHIFTS
1-2 @ 5250
2-3 @ 5250
3-4 @ 5000
MAX RPM/LIMITER- 5600
MAX SPEED- 110
TIMING- +1.75
SHIFT PRESSURE- + 12 ALL SHIFTS
STANDEARD SHIFTING- NO CHANGE
WOT- +1.55
My current stock wheels are 275x65-18 and I tried to plug in the manuals recommended 2559mm but it defaulted back to 2563mm. Tried twice so I guess thats as I can get. Is that cool?
Thanks for any input. I am trying to milk some more power out of this pig but be safe. If anything looks "unsafe" please let me know, thanks guys/gals
SHIFTS
1-2 @ 5250
2-3 @ 5250
3-4 @ 5000
MAX SPEED- 110
TIMING- +1.75
WOT- +1.55
Looks ok, some of the rev limiter and shift pressure are a little high for my taste but not too bad. The 4mm difference in the tire height is nothing. 4mm is only .157" a small load in the bed would change the tire height more than that.
intrested in doina custom tune myself.. i have been runnign lvl 3 for maybe.. 2 weeks now.. and have had the edge for about a month.. i have a 4.6.. does any body have any custom tunes for that, is it all the same.. aslo.. i wouldnt mind more power, but i dont wanna hurt anythign.. and my low end, 0-35 is alotttt better.. but after about 40 -60 it is a slug.. can i dont anything to improve (i have a CAI in progress).. thanks guys.. sry if im jackin the thread.
Originally Posted by bluejay432000
looks good except I would back off on 3-4 shift to 4800. That is a weak point in these trannys.
I would back off the timing to 1.00 and start from there. Level 3 on the EDGE is designed for 91 octane, and since you are running 93 you should only bump up your timing by 1.00. The general rule is half a degree in timing for every full point in octane. On my 05' I ran 1.25 on level 3, when I tried 1.5 I could feel it detonating thru the throttle pedal (it felt like a buzzing in the pedal under W.O.T.) and detonation will destroy an engine if left unchecked. So, I would start at 1.00 and adjust up from there, then when you feel it starting to detonate, back off .25 and you should be good.
Originally Posted by ThumperMX113
Everything looks good except I'd back the 3-4 shift down to 4700 rpms and drop the timing down to +1.
I will back my 3-4 to 4800 instead of 5000 for now and drop the timing to 1.25 instead of 1.75 and see how she runs. Can I just make those adjustments or do I need to replug them all in again? Thanks Thump!
You can load previous settings in the power programming setup, pick the level you want, hit enter, then at the bottom of the list load previous settings and then change what you want to.
There is an option to load your previous settings, do so and than edit what you need to and you'll be ready to load the new tune.
