anyone with stock 2wd shocks
Originally Posted by anaheim_drew
If you say so...
try a 265/40/22 on your 9.5 front rims and it will work...like you want it to....
285/30 22 and 265/35 22......
both of which would have a shorter sidewall than what I have now
that still doesnt help my offset problem
(dribone for ex has a +40 offset using the 265/35 22)
I've always had a hard time understanding the offset thing... eventually i'm going to move up to the 265/40's to fill out the wheel well a little more. you'll really tear up your rims on the curbs with the 265/35's.
OH YA, with your 3.5 drop up front how much clearence so you have between the tire and fender lip?
the only issue i would see with that is if you're going to slam the front, are you going to have enough travel so the tire doesn't rub directly on the fender lip?
I've got 2 and 3 inch drop coils ATM and maybe with another kind of drop (spindles shocks) I have a little room to play with
how was the clearence with the 3 inch coil? with the tire your runnin right now it looks like you could have went with a 4 inch drop
i've got 2 1/2" from tire to fender. 3" coil gave about 3" of clearance. hard ride though. 4" drop you could do a 2" arm and 2" coil. Hopefully in a couple weeks it'll drop ANOTHER 4 inches or so...
