Bed of the truck shakes at over 60 mph
Anyone have this problem? Once i hit 60 on the freeway i can feel and see out of my mirrors that my bed is shaking. I have no steering wheel nibble, but my passenger seat also shakes. I saw another F150 driving around today and his was doing the same thing. It seems some roads are worse than others.
I am going to go get my tires (Nitto Terra Grapplers 295 70 17) rebalanced to see what that does. But I want to know if is anyone else who has noticed this, and how did you resolve this.
I searched for a while and everything i read was about the e-brake hanging up.
I looked at the e-brake it is not hung up.
Sounds normal, I wouldn't lose any sleep over it. The cab is rubber mounted to pick up and absorb vibrations transfered into the vehicle. Remember you are riding in a 6,000# tank so there are a lot of vibrations.
I've read quite a few threads about this and my truck does it too. It starts at 62 and stops at 69. I believe I read that the axleshafts are not perfectly balanced. If you're that concerned about it try buying aftermarket axles. I just try not to drive between 62 and 69 mph.
Ive had had the bed wiggle ever since I installed the 35" tires. Which they say my rear left is out of round. Anyways from 55-65 mph my bed will shake pretty good. By any chance does anyone know if this will hurt my truck over time?
It will probably tear up steering, suspension and most likely tires.
Originally Posted by azfordby4
I was curious, will bad shocks cause this to happen.
My replies may be worthless, however, as I have consumed roughly 9 beers.
So I finally had time to drop the truck off for tire balancing at Big O on Guadalupe and the 101. Those guys are good. They said the tires were way out of balance. They rebalanced the tires and it is a night and day difference. Thanks Big O.
Anyways I had to have another one built. about two years later after trying to avoid the shimmy at 72-78 mph I decided to take it to have it harmonically ballanced. The people I bought my original one put a few weights on it for looks only (when I called them out on it they said if it is built true it doesn't need to be balanced). Well it was out of balance the whole time. As a result I was losing transmission fluid slowly through a worn out (wallowed out) seal at the back of the tranny (after a while not right away). It doesn't take too much time to get it re-balanced, just be sure to take it off your self and bring it in cause they like to charge $40 a bolt (X4 in my case) to remove from your truck. Just a heads up to avoid bigger charges in the future.
