Ollo HID Light Install
Old Jan 31, 2007 | 09:46 PM
Josiah's Avatar
Possibly Weazel or someone with any HID system. Did you drill into the headlight assembly. Also, where was the power source from? The directions give you no idea as to where to tap into the power, I figure I'm just reading past it.
Old Jan 31, 2007 | 10:12 PM
FX4REACTION1's Avatar
NO!!! No drilling into the headlight, is that what it wants you to do?
Old Jan 31, 2007 | 10:19 PM
Josiah's Avatar
I was able to install the foglights no trouble, just need to find a place to mount the ballast. Any ideas? Yes it asks you to drill a 25mm (.95 inch) hole into the back of the "Cap" but I believe I can bypass that step as I just installed almost everything.
Any ballast ideas, I have 4 of these bastards to mount lol.
Old Jan 31, 2007 | 10:21 PM
For the foglight ballasts mount them under the headlights theres a little ledge straight under the heads, and for the head light ballasts just drill them to your radiator cover thats how mine are, and no probs for over a year
Old Jan 31, 2007 | 10:25 PM
Josiah's Avatar
sounds good about to run out there and check. As for the radiator cover, there is clearance for these enormous things between the hood I'm assuming. They are at least an inch and a half thick.
Old Jan 31, 2007 | 10:27 PM
dont mount them straight on top, mount them on the angled part facing the engine plenty of room and just run the wires under straight to heads
EDIT: Josiah can you explain why you have to drill a hole in the heads? I dont understand what that would do or help???
Old Jan 31, 2007 | 11:43 PM
Josiah's Avatar
your guess is as good as mine, I didn't drill it...maybe weazel can chime in on his opinion. I just installed the 9005 on the pass side headlight, however I need to grind down a tab so I can get it in there. I believe this is typical.
Old Jan 31, 2007 | 11:50 PM
weazel's Avatar
Registered User
there is no need to drill any holes in the headlights, i had to hard wire the wires into the stock wiring harness.......you need to figure out which wire goes where!
Old Feb 1, 2007 | 12:13 AM
YellowFX4SCrew's Avatar
Ok, I'm now a little worried. I am pondering ordering a full set of these. Problem is that I am a NOVIST when it comes to these kinds of things. My concern is that I'll pay $340 and not be able to accomplish this.
Thoughts?
Old Feb 1, 2007 | 12:22 AM
weazel's Avatar
Registered User
Thoughts?
its not to hard.... trust me the fogs go in easy the heads are just a lil more thinking
Old Feb 1, 2007 | 01:18 AM
04procompLARIAT's Avatar
How are the cutoffs on these HID's? I had some and they blinded everyone. Is there something you can do to cut them off crisp like Lexus HID's?
Old Feb 1, 2007 | 01:24 AM
Josiah's Avatar
Weazel, I came on for what you just said. I am unsure of how to find the ground, did you solder these in there? I need to find an alternative method that is more "waterproof" =] Any sort of electrical glue I could try, soldering isn't my cup of tea. I can find the hot wire in the stock wiring harness, but the ground is going to take some tracing. Was the ground wire the middle wire (that would make it very easy) out of the three holes?
Old Feb 1, 2007 | 01:29 AM
Im pretty sure you can ground it on any metal surface.
Old Feb 1, 2007 | 01:31 AM
Josiah's Avatar
The thing is they come with special tips on the wires, let me post a pic check back in 2 secs. They specifically fit into the connector on the wiring harness...definitely not waterproof (@#$(*&%). I know I could ground it myself, just wondering if Weazel knows the slot offhand so I don't have to grind down some mud to get to the metal
Old Feb 1, 2007 | 01:32 AM
weazel's Avatar
Registered User
dude i wish i could be more helpful but when we did my we used a test light that showed what wire did what, also when we connect the wires in we use wire taps to get it connect so it wouldnt ruin the stockl wiring harness!
