i cant find a grommit in the cab??
Old Jan 31, 2007 | 08:06 PM
06FX4's Avatar
Question i cant find a grommit in the cab??
i want to run the Coax for my CB antennas in from under the truck but i cant seem to find a grommet in the floor of the truck that people have said about, can someone take a pic of where it is? thanks!
Old Jan 31, 2007 | 08:10 PM
Copenhagen848's Avatar
I don't know about the floor, but there is one on the firewall near the gas pedal if that helps
Old Jan 31, 2007 | 08:15 PM
Kool Aid's Avatar
Pull up the plastic cover over the channel, near the door sill.
Old Jan 31, 2007 | 08:23 PM
06FX4's Avatar
so its in there than, cause i was looking unerneath the truck but ill check tommorrow!
Old Feb 1, 2007 | 02:12 PM
06FX4's Avatar
well i looked under there and i didnt see any kind of grommets, does anyone have any pics?
Old Feb 1, 2007 | 02:21 PM
medic2586's Avatar
check in underneath the right side scuff guard cover at the back of the passenger door...it is a small black plug......located towards where the cover meets at the front of the back door....can see it from bottom....i ran the control wire for my Leer electric lock through it
Old Feb 1, 2007 | 02:26 PM
In every vehicle ive used one of the major wire exchanges at the door hinge area.
This is my 03 but you get the idea
Just come up between the outer and inner fender walls, and come in through the wire exchange. Depending on what direction you are coming from, there might be another small gromet you have to go through
Old Feb 1, 2007 | 02:36 PM
2006FX4's Avatar
I have a supercab and just yesterday found one on the drivers side towards the back of the Cab under the sill plastic. Crawl under the truck and right in front of the bed on the driverside of the cab there should be a black gromet. I ran my reverse light wire through there. And it goes right under the Loom of wires that run from the front to the back.
Old Feb 1, 2007 | 02:48 PM
06FX4's Avatar
cool thanks guys im goin to go look now!
