Cold Weather High Pitched Engine Noise
I have an 05 SCAB with the 5.4 and when the truck sits out in very cold weather I hear a very high pitched noise coming from the engine on start up. I comes and goes for the first few minutes after start up. It is not a belt and does not happen all of the time. Once the engine is up to temp the sounds go away. Any Techs seeing this problem ??
These modeular engines just make noise upon startup when they are cold...I use fully synthetic 5w-20 and it has done it since it was new.....others report the same thing....I don't knwo what to tell you!
Join the team. You think this would get more press and Ford would do something about it. It's kind of a big thing when you think about it. I've never seen another vehicle do it.
Duke
Duke
i got some kind of whining noise this morning at 6 degrees outside, for the first time on my 2004. sounds like the same noise my 1993 f150 makes a lot, but on it it comes from around the water pump pulley and the fan belt area.
