installed 1815 and have a question on tire size
Old Jan 23, 2007 | 01:22 PM
je3169's Avatar
Ok this is what i have i installed my program(1815 superchip) and i have 285/70-17's from the ground up i have 32 and a 1/8 inches @45psi so i set my tire size at 32 this is what i get at 60mph
speedo = 60mph
scan gauge II = 58
handheld GPS = 58
what is right the scangauge is reading from the PCM and the speedo gets its signal from the PCM so.......???
Thanks john
Old Jan 23, 2007 | 03:21 PM
je3169's Avatar
bump
Old Jan 23, 2007 | 03:41 PM
nuclearthreat54's Avatar
i have no clue
The scanguage is right, thats all i know
Old Jan 23, 2007 | 04:01 PM
maskins's Avatar
I have the super chips also on my truck and It is about a mile or 2 off compared my handled gps.
Old Jan 23, 2007 | 04:48 PM
je3169's Avatar
Thanks for the reply this is what i have learned
I just got back from trying 32.50,33 and 31.75 the GPS and the scangage are always the same dead on each other the speedo is always 2mph faster this leeds me to the speedo is 2mph off from the factory would you agree.
John
Old Jan 23, 2007 | 05:30 PM
PHS79's Avatar
The speedos are off 2-4 mph from the factory. This is because of the spring and such that is used for the speedo needle. I went through this same thing with my Edge, and alot of others have also. I just played with the numbers until I had my GPS and speedo reading the same and actually got it to within .2 mph, but then the Edge readout from the PCM was off (same reading as your scan gauge).
Old Jan 23, 2007 | 06:42 PM
je3169's Avatar
Hey PSH79 I see that you have a Airaid jr have you had any problems with it by that i mean the jr with the edge running lean I was told that sometimes with a tuner the motor can run lean I just bought one (airaid jr)and i have the 1815 tuner
John
Old Jan 24, 2007 | 10:13 PM
PHS79's Avatar
Hi John, check your PM's I replied there.
Paul
Old Jan 24, 2007 | 10:28 PM
je3169's Avatar
Thanks PHs79
Old Jan 24, 2007 | 10:34 PM
PHS79's Avatar
Not a problem, any time
