2wd lift
Old Jan 17, 2007 | 11:19 AM
Brandon Miller's Avatar
2wd lift
Who makes the best 4" and 6" 2wd lift for an '04 Crew Cab?
Old Jan 17, 2007 | 11:22 AM
Fabtech.
http://www.fabtechmotorsports.com/ap...04-05f150.html
Old Jan 17, 2007 | 11:50 AM
ThumperMX113's Avatar
I agree the Fabtech would be your best bet.
However just remember 2WDs sit 2" lower than a 4WD. So if you want to be the same height as a 4WD equipped with a 6" lift, you'll need 8" of lift. CST makes a badass 8.5" lift for 2WDs.
Old Jan 17, 2007 | 12:10 PM
charlie101's Avatar
As far as looks, I think the Pro Comp and Fabtech are about the same. I think they both use the spacer unless you buy the upgraded coilovers. For off roading, I'd say Fabtech.
Old Jan 17, 2007 | 12:17 PM
fx4jake31's Avatar
skyjacker just came out with a 2wd lift.. might want to look into that one
Old Jan 17, 2007 | 12:20 PM
This is just my opinion but the Fabtech front crossmember looks much better than Procomp's. The Fabtech kit doesn't use the spacer like the Procomp kit either, it uses longer struts and the factory coils.
Old Jan 17, 2007 | 01:09 PM
SAtownTX's Avatar
8.5? i only see a 7 inch on their website?
Old Jan 17, 2007 | 01:12 PM
SAtownTX's Avatar
i see 8 inch for 4wd but only 7 for 2wd
Old Jan 17, 2007 | 01:13 PM
Hmm, you're right. I swear I saw a 8.5" lift before, I don't know.
Old Jan 17, 2007 | 01:18 PM
SAtownTX's Avatar
damn i was hoping u were right
