I have a leak
Old Jan 17, 2007 | 11:57 AM
ThumperMX113's Avatar
I agree with everyone, its def. your axle seal.
Old Jan 17, 2007 | 03:03 PM
AKFX42004's Avatar
Made an appt at the dealer since it’s still under warranty, but it’s not till Tuesday. i just hope they are cool with the bigger tire and not say that what caused it.
Old Jan 24, 2007 | 12:17 AM
AKFX42004's Avatar
Well just got a call from the dealer and they have to replace both seals in my axle, replace rotors and calipers on all 4, fix the cam phaser and the burn out switch on the drivers door. The only think that suck is no truck till at least Sat, but everything was covered under warranty.
Old Jan 24, 2007 | 09:31 AM
Seems like you have a damn good dealership if they're fixing all of that with you only coming for the leaking axle seal.
Old Jan 24, 2007 | 11:04 AM
rms8's Avatar
So went into the garage today at lunch as saw a spot about 2in by 5in of fluid. It smells like gear oil but it is over where my passenger tire is. I looked under the truck at work and didn’t see any type of fluid on the axle or in the snow. I don’t think it’s the brake fluid since the color and the smell. The color of the leak is a clear with a little be of black in it. Any help would be great
An axel seal is an "O" ring. In the pic below (from my Mustang) you can see the black o-ring just above the break...
Old Feb 21, 2007 | 08:06 PM
JeffJeff's Avatar
i am having the same issue with nothing more than a 2 in level and brushgaurd on my 06. took it in once and they thought it was the strut and replaced it...i noticed the other side was doing the same thing...now im suspect. i havea call in to my service guy.
