Silverstar install?
Old Jan 11, 2007 | 07:59 PM
FoMoCoFan17's Avatar
Silverstar install?
Loooks like just a couple of bolts to get to it.
Any tips on installing my H13's.
Did a search. Not much...
Old Jan 11, 2007 | 08:03 PM
LovetheTide's Avatar
Its very straight forward just look in your manual.
Old Jan 11, 2007 | 08:14 PM
Devin4X4's Avatar
Pretty simple...
remove the bolts...unplug old bulbs....pop in the new ones
Old Jan 11, 2007 | 09:44 PM
Rockpick's Avatar
Moderator &
One push plug to remove the air dam material... two 9mm (?) bolts and the light will snap off after releasing a little 'snap' latch (you'll see it once you tug and it doesn't move). Click/Click (that's the bulb change). Reinstall. It's cake. Should take a person who hasn't handle a wrench no longer than 5 minutes.
cvc14's Avatar
There are 3 bolts holding the headlight in. 1 is on the top then the other 2 are on the inside side of the light behind the rubber cover. You are going to have to use a little force to pull out the headlight. There is a clip behind the side marker. So just pull the headlight straight out to the front of the truck.
Old Jan 11, 2007 | 09:46 PM
Budha05STX's Avatar
Unless you don't have your sockets organized like me. Took me longer to find a 9mm socket than to replace the bulbs. :o
Old Jan 12, 2007 | 01:23 AM
Piccolo's Avatar
Doesn't hurt to have someone with small hands around.
Old Jan 12, 2007 | 08:27 AM
NCSU_05_FX4's Avatar
Check this link to see how to install your new bulbs!
https://www.f150online.com/forums/sh...=253780&page=4
- NCSU
Old Jan 12, 2007 | 11:49 AM
2stroked's Avatar
One more important point- DO NOT touch the glass part of the bulbs. The tiny bit of oil your skin will leave on the glass leads to a hot spot and early bulb failure.
Old Jan 12, 2007 | 04:45 PM
Thanks for the install link. Didn't take 10 mins.
Now off to AAP for fogs.
Old Jan 12, 2007 | 06:26 PM
No problem, glad to help. Enjoy!
- NCSU
