wheel help someone with offset knowledge
Old Jan 8, 2007 | 08:03 PM
InCuBuS's Avatar
ok so i have a baer big brake kit and i mock installed it and it did not clear. my current wheel is a +35mm offset and looks like a need a half inch more clearance but dont want to use a spacer. i want to use a 22 so can someone tell me what offset i would need to make this work? one tire shop told me i would need a +25mm offset and a person at american racing wheels said a +30mm would work. any help is apreciated. thanks
Old Jan 8, 2007 | 08:10 PM
PHS79's Avatar
If you think that you need 1/2" then I would go with a +20mm wheel, this would give you the 1/2" plus a little bit. A +25mm wheel will only give you about 3/8" compaired to your current ones.
Old Jan 8, 2007 | 08:13 PM
InCuBuS's Avatar
ah it looks like my search is going to get tougher now. ive only found 2 wheels that were +25mm and one was going to have to be custom drilled.
