bull bar with tow hooks
Originally Posted by fx4jake31
be a lot easier and cleaner to mount a front hitch
What was the point of your post? The guy wants a bull bar, be it for looks, functionality or what have you. He also wants to retain the tow hooks. He was wondering if anyone had any suggestions and your advice is try out a front hitch?????
Uhm....thanks?
Originally Posted by Wookie
Because with a front hitch you could easily use a reciever mounted tow hook or D shackle that would function exactly like the factory tow hooks. Different means to the same end.
Yes, I'm pretty sure most are aware of how one could utilize a front mount hitch, but you can't have a front hitch AND a Bull Bar. But it's pretty POINTLESS to offer alternatives when the guy has ALREADY purchased the bull bar. The guy wants a Bull Bar. Maybe he likes the looks, maybe he wants lights on it. Maybe both.
He's looking for suggestions on how to integrate tow hooks with an already purchased Bull Bar.
Again....Uhm Thanks.
PS: I'm going to feel real stupid if you CAN install a front hitch and a bull bar at the same time.....but if you could, it seems like an expensive solution.
Uhm....thanks?
Uhm....thanks?
So how much does that front receiver cost? That would be an "ideal" solution, provided it isn't too costly. Would it present any sort of ground clearence issue for a non-lifted 4x4?
Originally Posted by 06FX4
its a draw tight hitch it was like 130.00 and as far as the the ground clearence its fine for me being lifted but even befor i was lifted it never got in the way.
Do the mounting tabs for the hitch go in between the Bull bar and the frame or does the bull bar go between the hitch and frame? I found one for $130 at
http://www.drawtite-hitches.com/fron..._main.htm#Ford
Not a bad price at all considering the trouble/time to get the original tow hooks to work!
Uhm....thanks?
Uhm....thanks?
"UHM" Your welcome
:o :o :o
