Headlight Question/Upgrade
Old Jan 6, 2007 | 04:28 PM
whaler417's Avatar
I am thinking of installing a set of Sylvania Silverstar headlights and foglights. Has anyone done this, and if so do the new bulbs make a difference? Also does anyway have the bulb numbers for both the headlights and foglights?
Old Jan 6, 2007 | 04:30 PM
CGATOR's Avatar
i have them and yes it does help headlights are h13 and the fogs i dont remember but im sure someone will tell you
Old Jan 6, 2007 | 04:36 PM
SAJEFFC's Avatar
Headlights are H13ST and the fog's are 9145ST or you can use 9005ST which is actually a high beam bulb for even more output.
Devin4X4's Avatar
I just put the silverstars in last weeked. H13st in the headlights and the 9145st in the fogs. Its definently an improvement over stock. Much whiter lighting
Old Jan 6, 2007 | 04:50 PM
top_sgt's Avatar
hadn't thought about the 9005ST!!! will have to check that out when i do my fogs........thanks.
Old Jan 6, 2007 | 07:15 PM
JonnyT's Avatar
Has anyone tried the silverstar ultras? I just saw them in the store. Was wondering if they were worth the extra 10 or so bucks.
Old Jan 6, 2007 | 07:17 PM
kingfish51's Avatar
Be careful, some have had problems using the higher power bulbs in the fogs. Not saying you will, but have heard of them melting the lens, melting the wiring harness, and exploding. YMMV.
As far as the H13ST and 9145ST, they both are improvements over stock. Have had the fogs in for quite a while, and the headlights for a few months.
