How to remove the panel under steering wheel?
Old Dec 30, 2006 | 06:04 AM
TeckBargins's Avatar
How do you remove the big panel under the steering wheel, theres a loose nut/screw that I have to get to. Any ideas?
Thanks!
Old Dec 30, 2006 | 09:53 AM
jrbhc8's Avatar
Don't quote me on this, but if I remember right there are 2 small bolts on the bottom of the panel. I think if you take them out, it will just slide out.
jrbhc8
Old Dec 30, 2006 | 01:01 PM
ChrisAdams's Avatar
Two small screws/bolts but then you have a very strong metal plate that protects your knees in an accident. That has four heavy bolts holding it in. Then you have full access.
The thin plastic panel is very easy to scratch and VERY expensive. The metal plate is cheap and indestructible. When you pull the trim panel set it somewhere safe.
Chris
Old Dec 30, 2006 | 02:17 PM
04yellowf150's Avatar
the small bolts are either 7 or 8 mm for the plastic cover
