Holy Crap Volant is LOUD!
IMO Volant is a TRUE cai as it is sealed from the engine heat (and the dynamat increases this insulation). If you ever go mudding or cross streams this also prevents crud from getting into your filter. It also can be modified to have a ram air tube installed. For those that have highly modified 4x4's but are afraid to get them dirty then the "open" CAI's would work fine. In my case I like to ford streams and mud bogs from time to time so its works fine for me.
Well i took the Volant intake off today.. I didnt feel like messing with sound deadening it and stuff. Im just going to try to return the intake and mabey go with an Airaid Jr. or somthing as i cant have an open filter under the hood.. (Way to hot in arizona along with city driving.)
I'm also having this same issue with the noise. I noticed the tube contacting the firewall when I installed it and I think this may be the source of the noise. I removed the lid and it seemed to get better, but not totally gone. How have you guys that had interference with the firewall get the right clearance? I just don't see how I can make it fit any better, I was lucky to get it all put together right.
Originally Posted by mkinttrim
Line the entire box including the lid with dynamat. I did mine and it totally wiped out the drone, now it sounds like a holly 780 dbl pumper!
I have an extra sheet of dynamat.
Originally Posted by Nates06SCab
I think the key is to damp the plate under the box. I happened to have some Dynamat laying around, so it wasn't a big deal to me...
wow! thanks for the fast replies, i guess ill just pick one and go w/ it
What do you guys think of the ram air feature for the volant? Should i get that at the same time or blow it off. .
