Are our rear ends or drift shafts weak?
Old Dec 27, 2006 | 05:27 PM
HIDPLANET's Avatar
I was playing around on the slippery roads since it just rained. Did one burnout (ive got LSD) and felt/heard a loud CLUNK! Then as I was driving away, the truck vibrates like crazy and I cant drive over 20 mph because of it. I havent looked at it but I have to go on a lift and see if somethings broken. Im sure somethings damaged, but im trying to guess at what it could be? Bummed out cuz my other car isnt running at the moment so I might be SOL.
Old Dec 27, 2006 | 06:30 PM
rocketir's Avatar
Might have been damaged due to wheel hop. Did you experience that when you were "burning rubber"
Old Dec 27, 2006 | 06:32 PM
patshea098's Avatar
that suycks and is weird....because me running 38's.....i do burnouts and nothing like that has happened...not clunks or anything...good luck
Old Dec 27, 2006 | 06:35 PM
HIDPLANET's Avatar
Yeah im pretty sure that was what happened. I felt it and let off as soon as it happened but I think the damage was already done. Whats the most common part to break due to wheel hop?
Old Dec 27, 2006 | 06:36 PM
Mark05KR's Avatar
Still trying to figure out what a drift shaft is.
Old Dec 27, 2006 | 06:39 PM
patshea098's Avatar
haha....kinda funny.
Old Dec 27, 2006 | 06:40 PM
HIDPLANET's Avatar
whoops..typo
Old Dec 27, 2006 | 06:43 PM
HIDPLANET's Avatar
You probably have trac bars.
Old Dec 27, 2006 | 06:45 PM
Maybe it had something to do with the lowering kit. I recall people breaking Mcgauhy's leafs before, if I recall correctly.
Old Dec 27, 2006 | 06:53 PM
HIDPLANET's Avatar
The leafs arent broken but they are soft.
Its probably the main reason why axle wrap happened in the first place.
I just need to know what to look for as far as broken or damaged parts before it gets towed to the dealer under warranty. Sucks cuz both cars I own arent operating now. My Supra is getting the ECU tuned and the truck is down now.....so im stuck.
Old Dec 27, 2006 | 06:57 PM
anaheim_drew's Avatar
There is a TSB on the rear end clunk issue
Old Dec 27, 2006 | 07:44 PM
04procompLARIAT's Avatar
Check your drive shaft U joints. If you had a lot of axle wrap you probably cracked one.
Old Dec 27, 2006 | 07:46 PM
patshea098's Avatar
no trac bars here.......hopoefully it was a fluke...good luck
what year supra? twin turbo?
Old Dec 27, 2006 | 08:05 PM
HIDPLANET's Avatar
89 with a 1JZGTE Twin Turbo Swap
Old Dec 27, 2006 | 08:10 PM
BHibbs's Avatar
Yea, the vibration leads me to believe you probably damaged a U-Joint. Shouldn't be too hard to fix...
