finally got an edge....wow!!
Old Dec 26, 2006 | 12:20 PM
06FX4's Avatar
Originally Posted by allrsdup
my god i love this thing. My truck is faster with the 37's i have then before it was lifted.
i have it on level 3 its amazing , i am shocked by how much of a difference it made.
thats good!!!! i cant wait to get mine now
Old Dec 26, 2006 | 12:30 PM
04yellowf150's Avatar
i want one
Old Dec 26, 2006 | 01:30 PM
hmfic's Avatar
Never realized that so many people still didn't have an EDGE or similair. I really couldn't even imagine not having it now.
Old Dec 26, 2006 | 01:41 PM
04procompLARIAT's Avatar
Ok so I changed to 4:10 gears and programmed my edge to the correct gear ratio but my speedo is now off. Any updates on this or do I still have the adjust the tire size to get the speedo right?
Old Dec 26, 2006 | 01:53 PM
khendrix2374's Avatar
Originally Posted by HiVoltage14.4
I chirped my 35's in the rain earlier on level 3.
Need a little more tweaking.
Old Dec 26, 2006 | 02:37 PM
ThumperMX113's Avatar
I was about to say the same thing!
I can ROAST my 37s in the rain without even trying.
Old Dec 26, 2006 | 03:20 PM
MosineeFX4's Avatar
When you change the gear ratio, you also have to change the tire size. I can't remember the explanation for it....I just remember that if you change one, you have to change the other also.
Old Dec 26, 2006 | 04:00 PM
HiVoltage14.4's Avatar
What did you guys do? I want a little more out of my level 2 while on 87 octane what should I do?
Old Dec 26, 2006 | 07:17 PM
effects4's Avatar
ok, now I have to get an Edge for my truck. I keep reading all these amazing stories and m getting jealous!! I already have the 4.10 rear end.
2004.5 FX4 supercab
Old Dec 26, 2006 | 07:44 PM
kingofkings's Avatar
I told you that you would love the edge.
Old Dec 26, 2006 | 07:48 PM
Oxlander's Avatar
No update needed. When you change the size of your tires, you are also changing the gear ratios. The gears in the differential is only one part of the formula for determining an accurate speedometer. The size of your tires is the other part. Use the following website to enter your equipment measurements and see how it will effect your speed in relation to your speedo.
http://www.web-cars.com/math/tiresize.html
On the Edge you must enter both values at the same time and any others that you wish to change and then save it to the truck's PCM. The Edge programmer will then write the new program over the old program that is already stored in the PCM.
Ox
Old Dec 26, 2006 | 11:28 PM
So when I change the tire and gear ratio I put in the formula for the bigger tires and then 3.73 axle ratio right? If so thats what I did.
Old Dec 27, 2006 | 12:46 AM
Muddoag's Avatar
If you were to say get a speeding ticket, and you saw the clerk of court ahead of time about a reduction in your speeding violation and she may have told you to get your speedometer calibrated. And lets say that you reprgramed your tire size with an Edge prior to getting said calibration and the aformention calibration reveiled that your speedometer was in error by 10 miles an hour, a Judge might be prompted to reduce your violation to improper equipment or dismiss said violation entirely. That said, you may still pay a fine but not have any points added to your driving record. I sumbmitt this postfrom a Holiday Inn Express I am curently staying at!
Old Dec 27, 2006 | 01:57 AM
Oxlander's Avatar
Yep, that sounds right. tire circumfrence (mm) and differential (3.73) Now your speedo will be accurate and your transmission shift points will be set.
If, in the future, you go back into the custom settings and change something, say speed limiter, you will also need to input the values for tires and gear again. Because the programmer re-writes the PCM entirely with the new program and it will wipe clean the previous saved programming.
Ox
Old Dec 27, 2006 | 08:30 AM
allrsdup's Avatar
i had the same problem setting up my speedo, but all is well now.....the more i have this thing the more i love it...u don't even have to get hard into the throttle to notice the increase in power and the throttle lag is now completely gone.....
