will this fit?
Old Dec 18, 2006 | 01:28 AM
athill's Avatar
will this fit?
ive been searching to see if this setup with fit without rubbing(or only very minor rubbing), but havnt had any luck.... on a 2wd with a 2.5 level kit.....
17x9 eagle alloy 187's w/ 5" backspacing
maxxis buckshot MT LT285/70R17
i know i can run 33s with the level kit on stock rims.... since these tires are alittle less than that should i be ok with the 5" backspacing?
Old Dec 18, 2006 | 07:59 AM
wandell's Avatar
It will probably be a tight fit, but I think they will work.
