HELP my truck is too fast...
Old Dec 14, 2006 | 02:55 AM
alex_pitts87's Avatar
Question HELP my truck is too fast...
alright nothing is "too fast" but i ran my 1/4 mile and 0-60 with a 14.73qt and 0-60 6.34 its not right could it be my tire size that i set my edge to?
dont get me wrong i like telling people that but i want a more accurate reading. thanks fellas
tiresize 2550mm stockers
Old Dec 14, 2006 | 03:29 AM
styxnpicks's Avatar
go to a drag strip
Old Dec 14, 2006 | 04:59 AM
Josiah's Avatar
14.7 is damn fast. I have my doubts but I would never tell someone they are lying about something so damn possible. It's possible but not likely, not sure about the tire size so hopefully someone chimes in to let you know. A buddy's 5.3 lowered reg cab 05 chevy runs a 15.3 and that sucker is pretty fast. I am not stock so that gives you an idea ;]
Old Dec 14, 2006 | 06:17 AM
MosineeFX4's Avatar
Just remember, if you set your tire size, you also need to set your gear ratio. What size tires do you have? My stock 18in BFGs "measured" out to 2480mm.
Old Dec 14, 2006 | 06:45 AM
styxnpicks's Avatar
last time I checked and inch equaled 25.4mm
pi is 3.14
circumfeence is pi times diameter.
so your tires must be like 32 inches tall?? I wasn't aware they made stockers that tall
Old Dec 14, 2006 | 07:32 AM
SSpiro's Avatar
Old Dec 14, 2006 | 08:33 AM
ericd's Avatar
Well, by the numbers, they do:
275/65R18 = 32.07" diameter / Circ. = 2557mm
255/70/17 = 31.05" diameter / Circ. = 2476mm
2550mm does seem a bit big though as it looks like you're running 17's. What size are your stockers? If they are the 255/70R17, try something around 2470mm.
If you want the most accurate measurement, take a tape measure to the tire. I used one of my wife's sewing tapes (the real flimsy fabric ones). Just backed over it and wrapped it around the tire. My stock BFGs on 18s also measured smaller than the calculation (2490mm if I remember correctly).
E...
Old Dec 14, 2006 | 08:44 AM
expy03's Avatar
You really should do a rolling measurement of the tire and use the formula in the EDGE instructions. It is the only way I got my odometer correct according to my GPS. No two tire brands are the same in diameter. Tread depth makes a big difference also.
Finally, you may also measure your tire’s circumference by marking your tire and rolling it one complete revolution and measuring the distance in inches or millimeters. If you measure in inches, multiply the distance by 25.4 to convert to mm. (ex. 91.3 inches x 25.4 = 2319 mm). The range of change is from 2000mm to 3500mm in increments of 1mm.
Old Dec 14, 2006 | 02:52 PM
thanks guys thats what ill do.
measure and do the formula just like math class all over agian
you guys rock
Old Dec 14, 2006 | 02:56 PM
I had the 255/65/17s for stockers and I believe they calculate out to 2398. Also, as someone else said, be sure the gears are correct. My Edge is preset for 3.73s so I have to change every time as I have 3.55s.
