will this lift/tire combo work?
Old Dec 5, 2006 | 04:33 PM
05STX's Avatar
I have a 2006 F-150 2wd supercab. I'm going to get the Fabtech 6" basic crossmember kit soon. I want to run some wide 33" tires with the Mickey Thompson Classic II rims in 18x10. The tires I like best are the Mickey Thompson Baja Radial ATZ. The size I was looking at were 375/50/18(33/14.76/18 per a calculator I found online). Will these fit on the rims I want and look ok with the 6" lift? I've seen some pics on here of some 4x4s with 6" lifts that hadn't upgraded there 33s yet and I thought they still looked pretty good. My 4x2 will be lower than these 4x4s with the same 6 inches of lift so I figure it will look even better. What do you guys think? Any other suggestions would be great too.
Old Dec 5, 2006 | 04:36 PM
wandell's Avatar
It will be close, but I think they will fit. It's hard to say because of the odd tire size. I know a member ran 325/60-18's (33x13.00) on 18x10 Mickey Thompson wheels with only a leveling kit and your truck would be taller than that with a 6 inch lift.
Old Dec 5, 2006 | 04:43 PM
05STX's Avatar
Thanks for the reply man. You think they might rub at full lock? Do you think it will leave too much tire to fender gap? It is true that a lifted 4x2 will be lower than a lifted 4x4, correct?
Old Dec 5, 2006 | 04:45 PM
wandell's Avatar
I'm not sure about the rubbing. Like I said, it's an odd tire size.
And yes, your 4x2 with a 6 inch lift is still gonna be about 2 inches lowerer than a 4x4 with a 6 inch lift.
