Amp Mounting
Old Nov 16, 2006 | 08:51 PM
brypink2's Avatar
Originally Posted by BestNTx
But I'm a 21 Y.O. college student who waits tables, lets just say my cash flow is not as much as I would like it to be.... I just found your in-dash screen for $735 what did you mean by combo???? I found the IVA-W200
The PXA-H701 is a processor that you can use with the W200. It's another $350, but well worth it. Dconder has the same set-up too. Alot of Car Audiophiles use this set up for it's SQ and versatility. Probably the best set-up I've used thus far.
Old Nov 16, 2006 | 08:54 PM
BestNTx's Avatar
I wish i could afford to nab that unit, i'm pretty sure i can use my amplink with that unit. The new amp im about to get delivered(should be here on tuesday) has an amplink feature that i can hook into most alpine HUs and adjust everything from the head unit...
Old Nov 16, 2006 | 09:07 PM
brypink2's Avatar
Yes you can. I forgot you were getting the Alpine amp. Then you could control your amps from the HU.
Old Nov 16, 2006 | 09:20 PM
BestNTx's Avatar
Hey so im in the middle of digging around in my truck, and i'm trying to figure out how to get the cover off my passenger side part of my dash(in between the passenger air vents, above the glovebox) how do i get this off, i know there is 2 screws when you open the glove box, but what else is there?
Old Nov 16, 2006 | 09:24 PM
brypink2's Avatar
I only took that off once...a while ago. I can't remember, but it seems like I had to get 2 more screws/bolts off from some odd place on it. Sorry, I'm not more help.
Old Nov 16, 2006 | 09:28 PM
BestNTx's Avatar
does the glove box come out?
Old Nov 16, 2006 | 10:14 PM
brypink2's Avatar
I just pulled down on the door...it drops all the way after you release it from it's stop.
Old Nov 16, 2006 | 10:24 PM
BestNTx's Avatar
I went out and figured it out, when you pull that cover off you have to take the 2 screws out where the glove box is, and then reach under the dash to the back of the cover by the ac vents and undo those screws, all in all, pain in the ***. I did all that to find out there was not enough room to mount the amp back there and then I had to reattach it so that was fun... I think it would have been impossible if i didnt have monkey arms...
Old Nov 17, 2006 | 12:16 AM
brypink2's Avatar
That's what I thought...I knew there were 2 odd placed screws somewhere.
Old Nov 17, 2006 | 12:25 AM
scsmitty78's Avatar
was there enough room to mount a PS2?
Old Nov 17, 2006 | 12:31 AM
BestNTx's Avatar
What are the demensions of a ps2?
I would say it was plenty wide enough and tall enough for a ps2. As far as deep you might have had about 6 or 8 inches. Of course you could fab something up to make it fit. There is plenty of room to mount a screen there though...
Old Nov 17, 2006 | 12:36 AM
scsmitty78's Avatar
PS2 is 12" wide 7" deep and 3 " thick. Gonna use a PS2 for DVDs and games.
Old Nov 17, 2006 | 12:38 AM
BestNTx's Avatar
That might actually fit. The only problem your going to have is access to it. With the dash cover on there is no access to anything back there.
Old Nov 17, 2006 | 12:42 AM
scsmitty78's Avatar
I would have the face of the PS2 showing through the panel. More than likely it will go in the center console. Thanks for the info
Old Nov 17, 2006 | 12:47 AM
BestNTx's Avatar
You could easily mount it there if you wanted to cut through the panel. There is even mounting brackets back there...
