Would like to bump up tire size a notch.
Old Nov 14, 2006 | 05:44 PM
AirJason's Avatar
I have a Screw Lariat with 275/65r18 tires on it and would like to up it a size both width and height and finding limited selection for ex 285/65r18. Also what tire size would be up one step in inches 32x11.5x18? Anyone know any brands that might have tires this size, seems like the 18" wheels are kind of limited with selection even on Tirerack.com.
Old Nov 14, 2006 | 07:01 PM
Adam06FX4's Avatar
Registered User
BFG all terain makes a 285/65R18
Old Nov 14, 2006 | 07:39 PM
OnBelay's Avatar
Bridgestone Dueller Revos
Old Nov 14, 2006 | 07:43 PM
FoMoCoFan17's Avatar
4x4? Get a leveling kit? Go for 35's!
Old Nov 14, 2006 | 08:00 PM
wandell's Avatar
Your OEM 275/65-18's are about a 33x11.00-18 tire. A 285/65-18 is essentially a 33x11.50 tire. BFG just started making the AT KO in a new size of 305/65-18 which is basically a 34x12.50-18 tire. Either of those should be fine. You could also add a 2 or 2.5 inch leveling kit and fit 35x12.50-18's.
Old Nov 14, 2006 | 09:53 PM
AirJason's Avatar
Do the Revos come in a 285 on an 18" rim, tirerack didnt have that size?
Old Nov 14, 2006 | 10:57 PM
tardman91's Avatar
Would I be able to cram a 305/70-17 on a 4wd screw without altering the suspension? That would be sweet. If not I think I'll go with a 295/70-17
Old Nov 18, 2006 | 02:13 PM
pacificnw's Avatar
Check out my 285 60 18's in a Toyo AT.
Old Nov 18, 2006 | 02:42 PM
Vapor_Trails's Avatar
pacificnw,
What kind of wheels are those? Your setup looks great!
