People With Headers, Need Help!
Old Nov 12, 2006 | 08:45 PM
weazel's Avatar
Registered User
Ok, heres my problem, every one know that this engine makes a ticking noise stock. Well i put the JBA headers on my truck and no the ticking noise is alot louder, is this something normal to expect with headers?
Old Nov 12, 2006 | 08:49 PM
a n t h o n y's Avatar
Banned
Most people don't inspect their gaskets and just throw them on assuming everything is alright, you may have an exhuast leak.
Old Nov 12, 2006 | 09:36 PM
allrsdup's Avatar
i agree if u alter your exhaust and now u hear a ticking, u have a leak my friend.
Old Nov 12, 2006 | 10:04 PM
weazel's Avatar
Registered User
well there was a ticking with the stock manifolds it just now with the headers it is a louder ticking!
Old Nov 12, 2006 | 10:22 PM
Banned
Where did you buy them from? There is a difference from fuel injectors ticking and exhaust...
Old Nov 12, 2006 | 10:23 PM
ThumperMX113's Avatar
. . but he said it got louder with the new headers so what gives?
Old Nov 12, 2006 | 10:27 PM
baja150's Avatar
Could be 1 of 2 things or both.
1) You had an exhaust leak and now it's worse frome either not replacing your exhaust gaskets or from damaging the surface when removing the old gaskets.
2) Whatever was making the noise before is now just louder because you're hearing it through the metal of a header which is about 1/4 the thickness of your original cast manifolds.
I'd bet on #2. The real culprit is probably some valvetrain noise... maybe a sticking or damaged exhaust valve.
Old Nov 12, 2006 | 10:28 PM
baja150's Avatar
Did you replace the exhaust gaskets?
Old Nov 12, 2006 | 10:38 PM
weazel's Avatar
Registered User
see the people that put the headers on didnt use the JBA gasket the use a scilicone to mount them, im pissed once i found that out, i want the gasket on!
Old Nov 12, 2006 | 11:05 PM
baja150's Avatar
Dude, I don't think they used silicone. If they did they have no right working on a engine. Do you know what kind of temperatures the exhaust manifolds or headers see? There is no silicone that will maintain a seal when exposed to that high temperature and if they used silicone then you have a leak.
Old Nov 13, 2006 | 12:08 AM
allrsdup's Avatar
where the hell did u find them?
Old Nov 13, 2006 | 12:16 AM
KSpencer's Avatar
If that is true, it is definitely one sheer act of stupidity. Have someone put the gasket in, and be sure that the surface is free of damage.
Old Nov 13, 2006 | 01:40 PM
weazel's Avatar
Registered User
I got the headers check for leaks by two exhaust Shops, and there were no leaks they were seal tight and they also said that the fords are metal to metal with manifold and that is it normal to use the silicone when mountig headers, they also said it is a high temp silcone used that has copper in it to keep from burning away, both shops said that the noise i hear is the injectors ticking but the header amplify it more due to that they are thinner in thick ness compared to the manifold.
Old Nov 13, 2006 | 07:44 PM
allrsdup's Avatar
thats strange i have had headers on a few of my vehicles and i never had them amplify noises from injectors.... interesting
Old Nov 13, 2006 | 07:53 PM
weazel's Avatar
Registered User
yeah i have no clue, im gonna look more into it!
