Edge Owners!!!
Old Nov 8, 2006 | 09:54 PM
weazel's Avatar
Registered User
Edge Owners!!!
hey guys. well i would like to know what every one is running on there edge settings wheather your 2wd or 4wd. Here are mine i am open to any fine tunning or suggestions!
Im running level three on 91 octane.
* 1-2 Shift = 5100
* 2-3 Shift = 5100
* 3-4 Shift = 5000
* Rev Limiter = 5600
* Timing: +1.00
* WOT Fuel = 1.60
* Shift Firmness = +2
* Tire Size = 2691 mm
Edit: Also post your 0-60 times
Old Nov 8, 2006 | 09:56 PM
Dian's Avatar
The level pre-tuned level 3 with tire size adjusted works fine for me.
Old Nov 8, 2006 | 10:09 PM
ThumperMX113's Avatar
Turn down your 3-4 shift!
Old Nov 8, 2006 | 10:31 PM
Yes to about 4800. I like firmer shifts, mine are at+12.
Old Nov 8, 2006 | 10:33 PM
FX4F150FX4's Avatar
Custom Level 3, 93 Octane...
* 1-2 Shift = 5500
* 2-3 Shift = 5400
* 3-4 Shift = 5300
* Rev Limiter = 5800
* Timing: +3.00
* WOT Fuel = 1.50
* Shift Firmness = +8
Old Nov 9, 2006 | 12:09 AM
alex_pitts87's Avatar
yeah turn down 3-4 shift and you should be fine
Old Nov 9, 2006 | 12:15 AM
bushtree's Avatar
your not really ever going to make the 3-4shift at the limit you set, seeing as that would put you well over 100mph (to lazy to figure out the exact speed) but just as a saftey you should set the 3-4 shift down to about 4600-4700.. If you ever did shift 3-4 at over those RPMs you can kiss your overdrive band bye bye..
Old Nov 9, 2006 | 12:20 AM
Dian's Avatar
So what does the pre-tuned level 3 setting that comes with the Edge have it set to shift at?
Should I mess with mine?
Old Nov 9, 2006 | 12:22 AM
Muddoag's Avatar
9200 first
9200 second
9200 third
9200 fourth
That's in my Craftsman Truck F150 though
Old Nov 9, 2006 | 07:45 AM
Silverfish's Avatar
Level 3 stock setting from Edge is 5000 rpm on 3-4 shift.
Old Nov 9, 2006 | 09:14 AM
gregbj33's Avatar
shouldn't timing be left at 0 when running tune 3 with 91 octane. If it cant be bumped up let me know. I thought 91 is supposed to be used and anything above that octane is when you move your timing up.
Thanks!!
Old Nov 9, 2006 | 09:20 AM
SSpiro's Avatar
Interesting..
I'm running standard level 2.
Old Nov 9, 2006 | 09:27 AM
Dian's Avatar
So are you saying that the only time my truck shifts into 4th gear is when I hit 5000 rpm in 3rd gear? Or how does this work?
Should I change it at all?
Thanks!!
You are correct. I was mistaken in thinking Level 3 was set for 89 octane. It is 91. So, if you are running 93, you can sart at +1. Depending on altitude, temp, etc., you may be able to run more or less. You will know if you have pinging to back off.
Old Nov 9, 2006 | 10:08 AM
FX4F150FX4's Avatar
Actually in the manual it says you can safely add 1.5 with 93 octane... I saw in a few other threads people bumped it up to 3 so I did the same with no sign of any pinging. I think I may try 4 if I'm feeling ballsy one day. lol.
