How can I repair a wire in my radio wiring harness?
If your talking about the pin in the block you could use a dab of super glue. Just make sure its sitting all the way in before it sets, and fully dries before reconnecting it.
I know some of you would probably disagree, however, I do a lot of aircraft wire repair in the Air Force and it is a legal practice (although its used as a last resort).
I agree with bronkx1, usually easy to fix. If wiggle testing has revealed the problem to be at the pin in the harness, I personally would try soldering it back in there. That is just what I personally would try. If that didn't fix it, I'd see about switching the harness out (if it is on the truck side of the connector) or switching to an aftermarket head unit (if it was on the head unit side of the connector).
Please refer me to the technical order that allows you to use super glue to fix a connector? In my 20+ years aircraft repair, I never saw anything that said you can use super glue. Does it work? Yes. Is it legal? No.
BTW, be careful with super glue as it is conductive until it has fully cured.
The pin should snap back into the connector. If not, one option would be soldering. Match the wire with the other connecting wire on the other side. Cut, strip, splice, and solder. Use heat shrink or electrical tape to keep it from shorting to ground. Or replace the connector. But, the pin should snap back in. Oh and no superglue.
