WEIGHT-DISTRIBUTING and sways bars
Does anyone know of any good weight distributing and sway bar systems?
If so what's a good system and a good price?
I will only be towing around 2 - 3 tons.
Any websites will help
thanks for the responses
Only 2-3 tons and you want to put on a WD hitch, why? I am not flaming you or anything, just asking. Since I am towing 4-5 tons 1-2 times a week and I used to tow 7 tons 1-2 times a month, without a WD hitch, just a 2 5/16 or pintle hitch depending on the trailer. Yes I know I should get a bigger truck...
I think this is in the wrong forum, but...I think that WD hitches are needed for excessive tongue weight, not total weight. I pulled a 5200 lb camper with a loading deck on the front like this http://www.kz-rv.com/coyote_rc/index.html. After putting 2 600 lb ATVs on the front, the hitch wgt jumps up dramatically. A WD hitch solved that problem
Thanks for replying
Well i tow a 35 foot trailer and can only put large heavy items in the front so thats why i thank that it would help. plus i mostly tow for 800 miles.
I run the Reese WD hitch with 800 lb. spring bars and no additional sway control to tow my 26 ft. travel trailer. Just the WD hitch improves the handling a great deal, you may not need an additional sway control device. Try the WD hitch first and work up from there. I used the same WD hitch for a 4500 lb. 19 foot travel trailer and it made a world of improvement over towing without it.
KC-10 FE out...
this one works really well
[url]http://www.rvsupplywarehouse.com.
go down to the hitches and look at the equil-i-zer. does both load level and sway control
Originally Posted by KC-10 FE
If no one else says it, I will: You're an idiot. That is all...
KC-10 FE out...
KC-10 FE out...
I've towed my camper with an Equalizer brand WD hitch for 2 years and it does a great job. I bought it at http://www.rvwholesalers.com/catalog...&cat=74&page=1 for $399 delivered. It has not gone to $419. It is a weight distributing hitch with sway control. To this I added the Prodigy brake controller for $99 (from same place) and it has proven to be an almost ideal setup for my needs. Hitch is explained at http://equalizerhitch.com/
Originally Posted by Monkey-1
You pull 14,000lbs with a half ton truck???
KC-10 FE out...
KC-10 FE out...
You just assume that since I posted this in the 04+ F150 forum, that I did this all the time with my 04. And after rereading my post, I could have worded it a little better.
I have towed both with and without WD hitches on a couple of different trailers, and personally I didn't see any huge change in the way that they towed. One trailer that I can think of actually towed much better without them, than with. This was a 28' enclosed trailer that we were taking on an ATV trip, with the WD the truck and trailer were bucking pretty bad. Took the bars off and everything smoothed right out. But just my $.02.
