AirRaid jr. kits??
Old Jan 16, 2007 | 02:49 AM
xlint1's Avatar
JR I don't know about. But the full CIA from Airaid wasn't good, it was gone in a few weeks. I use the K&N FIPK and can vouch for a definate power gain and increase in response with no CEL for $200 shipped.
Old Jan 16, 2007 | 09:28 AM
05supercrew's Avatar
This is the set up I will go with when they make a replacement oiless flat filter.
Old Jan 16, 2007 | 11:41 PM
HiVoltage14.4's Avatar
AMSOIL has a dry filter that goes in the stock airbox.Thats what Im gonna do I gotta get money first.
Old Jan 17, 2007 | 02:18 AM
xlint1's Avatar
Why is everyone hating on the oil type? It's been proven to work for years? Just curious.
Old Jan 17, 2007 | 11:48 AM
Ill take a look at it thanks
Old Jan 17, 2007 | 05:35 PM
James321's Avatar
05 supercrew, you helped with my exhaust so maybe I can help out here. I have the airaid tube and a k&n filter. This was the first mod I made to my truck when I purchased her. Everything was dead stock. After installation I noticed an increase in throttle response and the butt dyno recorded a marginal increase in "getty-up". For the money a good buy. Plus, since I am way down South and a normal rainfall is apx. 1 to 3 inches per rain storm, I like to have the airbox located up high..... hope this helps....
Old Jan 17, 2007 | 05:38 PM
Thanks I appriciate it. I agree about having the air box up high, I will be going this route. Thanks again.
Old Jan 17, 2007 | 06:15 PM
Becuase I like the new dry technology why oil when you can have it dry and not worry about it? I also am proably gonna get this kit just looking for some spare money.
Old Jan 17, 2007 | 07:03 PM
NASSTY's Avatar
The problem is not with oiled filters,it's when people clean the filter and over oil it.
Old Jan 17, 2007 | 07:06 PM
SAJEFFC's Avatar
Ok I too have been thinking of one of these. I like how it cleans up the stock engine compartment. Can it be used with the stock paper filter? Also where is a good place to get it from? Thanks for any info.
Old Jan 17, 2007 | 08:42 PM
cobraman302's Avatar
Yes you can use the Airaid Jr Kit with just a paper filter, or any other filter for that matter. You can just buy the modular intake tube without the filter for under $90. Not sure the best place to get them though, I think I got mine from Summit Racing.
Old Feb 4, 2007 | 09:56 PM
What should it be guys one of these with an AMSOIL dry filter or a new S&B intake along with a magnaflow muffler only with my Edge?
Old May 2, 2007 | 10:54 AM
po'man's Avatar
I recently added / removed the Outlaw Intake system because of the mid range drone. I only had it installed for 4 days and 100 miles.
Drone: Normal acceleration is great. Wide open throttle is acceptable. At 2000 RPM under engine load the drone is miserable. (hills in OD, etc)
To explain: I have the 50 series Flowmaster on this vehicle and had the 70 series on my old one and I preferred the 70 series. I just don’t like hearing much in the cab at all.
Mods:
Edge stage 2 (max std shift points and reduce WOT shift points)
Flowmast 50 series S
Will I have the same trouble with the Airaid Jr?
What does the tube connect to behind the headlight?
Old May 2, 2007 | 11:09 AM
KSpencer's Avatar
Mods:
I doubt that you will have any drone with this setup. Very little difference from stock (sound-wise). The tube is supported by the stock bracket, so the end just sits behind the headlight without connecting there.
Old May 2, 2007 | 12:18 PM
Mods:
It sounds to me like your exhaust is your problem not the intake. Im about to get the Outlaw cai now im wondering if there is a problem with the Magnaflow exhaust.
