lowered guys
Old Oct 24, 2006 | 08:03 AM
styxnpicks's Avatar
not needed. the kit comes with some lo-pro bumpstops tho
Old Oct 24, 2006 | 08:06 AM
Dribone's Avatar
i just saw this post... if you're going to be hauling, or towing, or crankin through the backroads, i would suggest getting a notch to put in there. the flip kit and the low profile bumpstops give you limited travel, about 2-3 inches. the DJM arms are by far the best, but if you're going to set up a 3 inch drop up front, i would suggest the 2" arms and a 1" drop coil, which would be a little stiffer than stock, aloowing for better cornering.
i would suggest a driveshaft hoop as well. just a little added insurance so if it does let go, its not tearing up absolutely everything.
Old Oct 24, 2006 | 08:28 AM
anaheim_drew's Avatar
Originally Posted by Dribone
i would suggest getting a notch to put in there. the flip kit and the low profile bumpstops give you limited travel, to set up a 3 inch drop up front, i would suggest the 2" arms and a 1" drop coil, which would be a little stiffer than stock, aloowing for better cornering..
The c-notches are a pain in the azz for what you get in return.
Notch the cross member and you can run 6" in the rear. Front 2" control arm and 2" springs would give you what you are looking for.
Old Oct 24, 2006 | 03:24 PM
gatortech's Avatar
now where is the best place to buy the parts seperate? All of the kits come with the 3" drop arms. And i like the idea of the 2" arms and 1" springs. thanks for the help thus far.
Old Oct 24, 2006 | 03:37 PM
Dribone's Avatar
talk to anaheim drew about that one... he can find ya just about anything.
Old Oct 24, 2006 | 07:30 PM
05_F150's Avatar
Originally Posted by HIDPLANET
Dont forget about McGaughy's Suspension System. $700 installed or $450 for parts. You get relocation for the fronts and new repacement leafs for the rears.
With the new leafs, you cant haul much in your bed or tow as much, but if you dont do those things to begin with, its a great setup.
I had the Mcgaughy's 2/4 (Front coil-overs, rear leaf springs). It sits prefectly even and rides great. The only problem I had were my rear leafs were really soft and not good for towing (unless u get air helpers) or for heavy acclertion off the line. I am on my 3rd drive shaft and now I am back to my stock leaf with the 2" drop shackle so it sits 2 inch higher in the rear with the front still 2" lowerd. Future plans are to get the rear DJM flip kit with the lifter hangers, or to sell mine and get the whole djm setup.
Old Oct 24, 2006 | 07:34 PM
InCuBuS's Avatar
are you supercharged? cause i give my truck hell and i have no driveshaft trouble. i am thinking about doing a flip kit cause i want to be able to tow and not bottom out
Old Oct 24, 2006 | 07:49 PM
05_F150's Avatar
No, but I have enough power to spin my 24 inch ZR rated tires and my rear leafs didnt alot them to spin and it would wheel hop and thats why I was brecking and twisting drive shafts. warrtied the 2nd one but had to come outta pocket for the 1st.. werid u would think i woulda got it fixed free the frist time not the 2nd (2nd I had my stock wheels n leafs on)
Old Oct 25, 2006 | 12:16 AM
Smok][n's Avatar
dont know if u have seen this thread but it might be something to keep in mind if u are planning a flip kit.
https://www.f150online.com/forums/sh...d.php?t=254875
Old Oct 25, 2006 | 01:16 AM
styxnpicks's Avatar
here's another good question:
just how low of a static drop can we use in the front?
Old Oct 25, 2006 | 01:24 AM
that would depend on your tire size, budget, desired end result
Old Oct 25, 2006 | 01:46 AM
styxnpicks's Avatar
275/45/22
budget doesn't matter
as low as possible but still being able to drive it on the street
Old Oct 25, 2006 | 02:28 AM
275/45/22
3.5-3.75 dpending on the inner fender due to your tire size.
Justin on the other hand could go down to 5 in the front
Old Oct 25, 2006 | 09:45 AM
Dribone's Avatar
this would be 5/8 for me...
this would also be lower valance devastation for me.
this would also be oil pan, transmission, driveshaft and fuel tank failure
(where i live)
Old Oct 25, 2006 | 10:01 AM
styxnpicks's Avatar
(where i live)
I had a buddy with an s-10 xtreme that sat like that. bout 1 inch between the bumper and ground and tuckin tires. he liked scraping gum off the streets. lol j/k
