Engine start??
Old Oct 22, 2006 | 01:03 PM
Budha05STX's Avatar
Originally Posted by patshea098
hmmm....you mean when it didnt turn over did it do that? if so...i dont remem....
Maggnuson/Moss Warranty Act. whats this???
Something you should have checked out from the instant you wanted to mod your truck.....search the net for it, it'll give you some good info and backing when your service writer starts to give you chit about all your aftermarket mods.
Old Oct 22, 2006 | 01:15 PM
a n t h o n y's Avatar
Banned
TSB 05-19-1 MIL ON - VARIOUS DRIVEABILITY CONDITIONS - 5.4L 3-VALVE ENGINE - VEHICLES BUILT BEFORE 4/20/2005
This TSB addresses Hard start/long crank/cranks-no start , check if your truck was built prior to 4/20/2005. I guess after they hit the reefer that day they found out was was going on.
Good Luck!
Old Oct 22, 2006 | 01:33 PM
patshea098's Avatar
well my truck was builkt 6/05 now what....
Old Oct 22, 2006 | 01:36 PM
Banned
TSB
06-19-14 NO CRANK / STARTER TERMINAL FATIGUE
Some vehicles may exhibit a no crank condition due to an open circuit in the starter relay to starter motor circuit at the starter motor connection.
A new starter terminal wiring pigtail kit is released eliminating the need to replace the entire harness for the terminal connection.
6U2Z-14S411-NA Wiring Pigtail Kit
Old Oct 22, 2006 | 01:37 PM
Monkey-1's Avatar
Stragum has that same issue and it has been in the shop several times. You might contact him and ask him what they have told him.
Old Oct 22, 2006 | 02:07 PM
CANNONFX4's Avatar
outta warranty after the lfit and gearing.....
It should be covered. My dealership actually sells 150s with the Rize lift so they have to cover it.
Old Oct 22, 2006 | 02:10 PM
ThumperMX113's Avatar
